Gravity: Analog Turbidity Sensor for Arduino
$9.90
SKU: SEN0189
  • $9.80 2+ items
  • $9.70 5+ items
  • $9.50 10+ items
Turbidity sensor measures water quality by detecting particles via light transmittance. Features analog/digital outputs, adjustable threshold, not waterproof.
The Arduino turbidity sensor detects water quality by measuring the level of turbidity. It is able to detect suspended particles in water by measuring the light transmittance and scattering rate which changes with the amount of total suspended solids (TSS) in water. As the TTS increases, the liquid turbidity level increases. You may also check Liquid Sensor Selection Guide to get better familiar with our liquid sensor series.
This Arduino turbidity sensor has both analog and digital signal output modes. You can select the mode according to the MCU as the threshold is adjustable in digital signal mode.
Turbidity sensors can be used in the measurement of water quality in rivers and streams, wastewater and effluent measurements, sediment transport research, and laboratory measurements.
Please note that the top of probe is not waterproof!
Quick Comparison of the Water Quality Turbidity Sensors
Figure
SKU
SEN0189
SEN0554
SEN0710
Add to Cart
Principle
Light transmittance & scattering rate change
Infrared light transmittance & scattering (non-contact)
90° light scattering method
Method
Contact type, probe immersed in liquid
Non-contact, mounted on outer container wall
Contact type, probe immersed in liquid (IP68)
Output
Analog voltage 0–4.5V / Digital high-low level
UART-TTL (9600 bps)
RS485 (ModBus-RTU)
Range
Relative turbidity (no NTU value)
0–1000 NTU (resolution 0.1 NTU)
Temp. Compensation
Built-in, 0–60℃ automatic compensation
Power Supply
5V DC
5V DC
10–30V DC
Waterproof Rating
Probe tip immersible, top not waterproof
Non-contact, no waterproof requirement
IP68 fully waterproof, can be submerged long-term
Response Time
<500ms
<1s
≤30s
Installation Requirements
Direct immersion, protect the top
Container diameter 40–50mm, transparent cylinder
Submersible; keep >5cm clearance around, 7cm obstacle-free below the probe
Typical Applications
Arduino education, simple experiments
Arduino education, corrosive liquids, non-contact required
Industrial wastewater, drinking water monitoring, environmental IoT
  • Operating Voltage: 5V DC
  • Operating Current: 40mA (MAX)
  • Response Time: <500ms
  • Insulation Resistance: 100M (Min)
  • Output Method: Analog/Digital
  • Analog Output: 0-4.5V
  • Digital Output: High/Low-level signal (you can adjust the threshold value by adjusting the potentiometer)
  • Operating Temperature: 5℃~90 ℃
  • Storage Temperature: -10℃~90℃
  • Weight: 30g
  • Adapter Dimensions: 38mm*28mm*10mm/1.5inches *1.1inches*0.4inches
  • Turbidity sensor adapter x1
  • Turbidity sensor probe x1
  • Turbidity sensor cable x1
  • Gravity analog sensor cable x1
Certifications
Dec 28, 2019
GSM &amp; SMS Enabled AI-driven (TinyML) Water Pollution Monitor
Projects GSM & SMS Enabled AI-driven (TinyML) Water Pollution Monitor
Kutluhan Aktar
Mar 31, 2022
wajdi. Oct 21, 2022
Very good as description
wajdi. Oct 21, 2022
Chih.Kuo Dec 01, 2021
good. Wish it was waterproof
