If you have purchased an older version LattePanda but want to use the newer capacitive touch panel, you can download the V1.1 drivers below and manually install them.
PLEASE NOTE: “install.bat” must be run as an administrator to update the driver correctly.
NOT compatible with LattePanda Alpha and Delta edition
What is LattePanda?
A LattePanda is a complete Windows 10 single-board computer! It includes everything a regular PC has and can do anything that a regular PC does. It is compatible with almost every gadget you know: printers, joysticks, cameras, and more. Any peripherals that work on your PC will work on a LattePanda. A LattePanda comes pre-installed with a full, pre-activated version of Windows 10, where you can install powerful tools such as Visual Studio, NodeJS, Java, Processing, and more. Using existing APIs, you can develop your own software and hardware projects on a LattePanda as you would on a normal PC - C#, Javascript, Ruby, and so on. Say goodbye to your bulky laptop!
Oct 17, 2021
Working perfect, using on a LattePanda i installed to control a CNC, makes using the machine way easier.
