DFRobot Double‑Sided USB 2.0 to MicroUSB Cable delivers reliable power delivery and stable data transfer for compact computing platforms and mobile electronics. Featuring a reversible USB connector engraved with the LattePanda logo, this charging and data cable simplifies connection while maintaining consistent electrical performance. High‑quality conductors support up to 2.1A current for efficient charging alongside USB 2.0 data communication. Durable aluminum connector housings and flexible TPE insulation improve longevity in everyday use. Designed for compatibility with LattePanda single board computers, smartphones, tablets, and other MicroUSB-powered hardware, this flat cable offers dependable connectivity in both development environments and daily charging scenarios.
Reversible USB Connector for Easy Connection
A double‑sided USB 2.0 connector eliminates orientation frustration common with traditional USB cables. Either insertion direction works correctly, simplifying connections during hardware development or device charging. The engraved LattePanda logo highlights compatibility with LattePanda single-board computers and related embedded systems. Such reversible USB design improves convenience when connecting development boards, edge computers, or mobile electronics in tight workspaces where visibility or access may be limited.
2.1A Fast Charging with Stable Data Transmission
This MicroUSB data and power cable supports current up to 2.1A, enabling efficient charging while maintaining USB 2.0 data communication. Stable electrical characteristics allow simultaneous power delivery and file transfer for development boards, tablets, smartphones, and compact PCs. Integrated multi‑stage voltage protection enhances operational safety and maintains consistent performance during extended use in embedded computing setups or mobile charging applications.
Flat Noodle Cable Design Prevents Tangling
A flat noodle-style cable structure significantly reduces twisting and knotting compared with conventional round cables. Flexible TPE insulation improves durability while maintaining easy storage and cable routing across workbenches, robotics builds, and portable computing kits. Combined with corrosion‑resistant aluminum connector shells, this durable USB power and data cable maintains reliable performance across repeated connection cycles in maker labs, classrooms, and engineering workspaces.
About LattePanda Single Board Computers
A LattePanda platform represents a complete Windows 10 single board computer integrating the functionality of a full PC within a compact embedded system. Compatibility with peripherals such as printers, cameras, joysticks, and USB accessories enables a wide range of development scenarios. Pre‑installed Windows environments support tools including Visual Studio, NodeJS, Java, and Processing, allowing software and hardware development using languages such as C#, JavaScript, and Ruby on a compact computing platform.
This MicroUSB charging and data cable serves development boards, embedded PCs, smartphones, and tablets requiring dependable USB power delivery. Common usage includes LattePanda computing projects, portable electronics charging, maker prototyping setups, and compact workstation environments where durable and tangle‑free USB connectivity improves workflow efficiency.
Oct 17, 2021
NIfty accesory for the LattePanda. All USB Cables should be double sided like this!
Jan 21, 2025
Very practical cable.
Jan 21, 2025
