Gravity: DSS-P05 Tilt / Pan Kit (4.5kg)
$15.00
SKU: FIT0045
Pan and Tilt assembly for horizontal mounting with two ball bearing servos. It includes brackets and hardware but can't achieve full vertical rotation.
Purchase this product and earn 150 reward points, which are tied to VIP membership program. Learn More >
The two-degree-of-freedom DSS-P05 servo gimbal is a high-value, small-scale gimbal boasting a considerable torque of 4.5 kilograms. It can execute two degrees of freedom movements in both horizontal and vertical directions, facilitating the convenient installation of cameras. This enables image surveillance, as well as image recognition and tracking. By integrating an infrared sensor or an ultrasonic distance-measuring sensor, it can be transformed into a comprehensive detection device, allowing robots to perceive surrounding obstacles and thereby enabling obstacle avoidance. Of course, it can also accommodate various sensors, and through the Arduino controller, it can facilitate the creation of numerous innovative interactive works.
Please note: The DSS-P05 servo has superseded the previous version, the DF05BB. Due to the hardware constraints of the servo and U-shaped bracket in the horizontal position post-assembly, the product cannot achieve 0-360° rotation in the vertical direction.
  • Voltage: + 4.8~6.0V
  • Idle Current: 20mA (4.8V), 25mA (6.0V)
  • No-load Speed: 0.14 seconds/60 degrees (4.8V), 0.12 seconds/60 degrees (6.0V)
  • Torque: 3.5 kg/cm (4.8V), 4.5 kg/cm (6.0V)
  • Operating Temperature: -10℃~60℃
  • Servo Wire Sequence: Brown wire for power negative, Red wire for power positive, Yellow wire for control signal.
  • Dimensions: 40X20X44.5mm
    • DSS-P05 Standard Servo x2
    • Aluminum multifunction bracket x1
    • Aluminum U-shape bracket x1
    • Bearing cup x1
    • High-quality sets of screw nuts x1
    How To Build A Robot— Lesson 4: Build An Arduino Robot That Could Avoid Obstacles
    Blog How To Build A Robot— Lesson 4: Build An Arduino Robot That Could Avoid Obstacles
    Dec 16, 2016
    Geoff. Jul 24, 2025
    This product worked great for rotating small objects!
