Turbo Metal Gear Worm Motor (12V 160RPM 2.2kg.cm)
$18.90
SKU: FIT0489-C
The metal gear worm motor is durable, self-locking, supports direction and PWM speed control. Rated at 12V, 160RPM, with 2.2kg/cm torque.
The turbo metal gear worm motor uses a metal gear box for durability and a high torque output. Due to the special mechanical structure of the worm drive the motor output shaft is self locking and can not be rotated.
(From wikipedia)
This part uses a two wire connection and supports direction control as well as PWM speed control. Rated voltage is 12v and will achieve 160RPM, with a torque of 2.2kg/cm.
Warning: Do not stall motor for extended periods of time to avoid damage to the gearbox.
  • Operating Voltage: 6 - 15 V
  • Rated Voltage: 12V
  • No-load Speed: 160 RPM
  • No-load Current: 35 mA
  • Rated Torque: 128 RPM
  • Rated Current: 180 mA
  • Rated Torque: 0.55 kg.cm
  • Rated Power: 1.1 W
  • Stall Torque: 2.2 kg/cm
  • Stall Current: 1 A
  • Reduction Ratio: 1:37.3
  • Weight: 165 g
  • Metal Turbo Worm Gear Motor (12V 160RPM 2.2kg.cm) x1
Only 19 Left
