Metal Turbo Worm Gear Motor (12V) delivers compact high‑torque actuation through a durable metal gearbox combined with a worm‑drive reduction system. This geared DC motor integrates a 1:150 reduction ratio to produce strong output force while maintaining controlled rotational speed, making the actuator suitable for robotics mechanisms, smart equipment, and mechanical automation projects. The worm gear transmission also provides inherent self‑locking behavior, preventing the output shaft from being rotated externally when power is removed. Such characteristics make the compact power unit particularly valuable for motion systems that require stable positioning, torque retention, and reliable long‑term mechanical performance.
Figure: Worm gear mechanism (from Wikipedia)
Note: Warning: Do not stall motor for extended periods of time to avoid damage to the gearbox.
Self‑Locking Worm Drive Structure
The integrated worm gear transmission forms a mechanical self‑locking system where reverse rotation from the output shaft is prevented. This structure enables the geared actuator to maintain position without continuous power, which is especially useful in lifting mechanisms, robotic joints, valve control systems, and adjustable platforms. The design also improves mechanical stability and reduces the need for additional braking systems, simplifying overall system architecture.
High Torque Metal Gearbox
A full metal gear reduction assembly provides strong durability and reliable torque output even under demanding mechanical loads. The internal 1:150 reduction ratio amplifies motor force to achieve stall torque up to 8 kg/cm while maintaining compact dimensions. Compared with plastic gear alternatives, the metal gearbox improves wear resistance, load capacity, and long‑term operational stability, making the gear motor suitable for robotics drive systems, mechanical linkages, and automated equipment.
PWM Speed and Direction Control
This two‑wire DC motor supports direction switching by reversing polarity and allows precise speed regulation through PWM control when paired with a motor driver. The flexible control method enables easy integration with common embedded controllers and robotics platforms, providing adjustable motion profiles for automation systems, intelligent machines, and experimental prototypes.
Figure: Motor dimensions
Thanks to its compact footprint, strong torque output, and worm‑gear self‑locking capability, this gear reduction motor is widely used in robotic mechanisms, smart door systems, positioning platforms, automation devices, and educational mechanical engineering projects requiring stable low‑speed motion.
