Gravity: Starter Kit for Genuino / Arduino 101 with Tutorials(Discontinued)
SKU: KIT0113
Discontinued
Gravity: Starter Kit is discontinued. We recommend Arduino Kits as replacement where you might find other products interested.
DFRobot's Gravity Genuino (Arduino) 101 Starter Kit is an absolute beginner kit to get started with Arduino/Genuino 101. It comes with 11 projects with easy to follow tutorials. The Gravity interface (Plug&Play) provides the kit a fantastic user experience while keeping the great expandability. It is an excellent kit for STEM and Maker education.
This Starter Kit includes a Genuino 101 (Arduino 101 in USA) board, the latest Arduino compatible board running on a Intel curie processor, featuring functions such as gesture recognition and Bluetooth communication. The kit comes with 13 most popular sensors, modules together with an easy-to-plug IO expansion shield, allowing users to build various interactive projects without using breadboards or jumper wires. Sensors in the kit are highly modularized that can be simply attached to the shield via DFRobot's  Gravity interface which is a standard color-coded 3-pin design. Different types of sensors can be easily identified by the logo printed on the back. More than 200 DFRobot sensors and modules are available to power further projects.  All components included in the kit are fully compatible with Arduino microcontrollers.  With the starter Kit for Genuino 101, building your own project will just be as simple as stacking blocks.
Starter Kit for Genuino/Arduino 101 also provides 11 step-by-step tutorials, which aims to help Arduino beginners to understand Arduino programming. The tutorial goes through the installation of the Arduino IDE, its programming language, how to build electric circuit, how to use different electric components and their signaling. It also includes instruction for building projects from lighting up an LED to eventually use 101 with multiple components to make a real project such as “Weather Station” or “Electronic Gradienter”. The tutorial is filled with tons of pictures and diagrams so that anyone can build their own arduino project without any difficulty.
The kit does not require any soldering and is recommended for Arduino class or STEM/Maker education.
Tutorial Includes:
  • Arduino Platform and Genuino/Arduino 101
  • Analog and Digital Signals
  • Simple Automatic Control Devices
  • Project 1. Make an LED Blink
  • Project 2. Sensor Light
  • Project 3. Mini Lamp
  • Project 4. Sound Activated LED
  • Project 5. Fading LED
  • Project 6. Light Regulator
  • Project 7. Pandora's Box
  • Project 8. Bluetooth Connection
  • Project 9. Weather Station
  • Project 10. Open Sesame
  • Project 11. Electronic Gradienter
  • Microcontroller: Genuino/Arduino 101
  • Power Supply: 6*AA Batteries or 6.5-12V AC power adapter
  • Dimension: 220mm * 165mm * 65 mm/ 86.6 * 65 * 25.6 inches
  • Weight: 300g
Arduino Platform and Genuino101
Blog Arduino Platform and Genuino101
May 10, 2017
Arduino/Genuino 101 Starter Kit Tutorial - Lesson 6: Sensor Light
Blog Arduino/Genuino 101 Starter Kit Tutorial - Lesson 6: Sensor Light
May 26, 2017
Arduino/Genuino 101 Starter Kit Tutorial - Lesson 2: Digital and Analog Signals
Blog Arduino/Genuino 101 Starter Kit Tutorial - Lesson 2: Digital and Analog Signals
May 10, 2017
Arduino/Genuino 101 Starter Kit Tutorial - Lesson 8: Sound Activated LED
Blog Arduino/Genuino 101 Starter Kit Tutorial - Lesson 8: Sound Activated LED
May 31, 2017
Arduino/Genuino 101 Starter Kit Tutorial - Lesson 9: Fading LED
Blog Arduino/Genuino 101 Starter Kit Tutorial - Lesson 9: Fading LED
Jun 26, 2017
Arduino/Genuino 101 Starter Kit Tutorial - Lesson 5: Electronic Gradienter
Blog Arduino/Genuino 101 Starter Kit Tutorial - Lesson 5: Electronic Gradienter
May 18, 2017
