Gravity: Non-contact Digital Liquid Level Sensor for Arduino
$11.90
SKU: SEN0204
  • $11.60 5+ items
  • $11.40 10+ items
  • $11.00 50+ items
Non-contact liquid level sensor for Arduino, using a high-speed chip for toxic or high-pressure liquids. Compatible with Gravity interface, with adjustable sensitivity.
This is a non-contact water / liquid level sensor for Arduino. It utilizes advanced signal processing technology to achieve non-contact liquid level detection.No contact with liquid makes the module suitable for hazardous applications such as detecting toxic substances, strong acid, strong alkali, and all kinds of liquid in an airtight container under high pressure. There are no special requirements for the liquid or container and this liquid sensor is easy to use and easy to install. You may also check Liquid Sensor Selection Guide to get better familiar with our liquid sensor series.
Non contact liguid level sensor
The liquid level sensor is equipped with an interface adapter that makes it compatible with DFRobot "Gravity" interface. The sensitivity can be adjusted via the potentiometer knob on the back of the sensor.
Gravity: Non-contact Arduino Water Liquid Level Sensor XKC-Y25-T12V
Diagram for Non-contact Liquid Level Sensor with Arduino
  • Operating Voltage (InVCC): DC 5 ~ 24 v
  • Current consumption: 5 mA
  • Output voltage (high level): InVCC
  • Output voltage (low level): 0V
  • Output current: 1 ~ 50 mA
  • Response time: 500 ms
  • Operating Temperature: 0 ~ 105 ℃
  • Range for thickness of induction (sensitivity): 0 ~ 13 mm
  • Humidity: 5% ~ 100%
  • Material: ABS.
  • Waterproof performance: IP67
  • Dimension: 28 * 28 mm / 1.1 * 1.1 inches
  • Liquid Level Sensor Probe x1
  • Liquid Level Sensor Adapter x1
  • Gravity Digital 3-Pin Cable x1
Dec 28, 2019
dancy.dai Sep 09, 2021
good!!!
