Gravity: I2C Non-contact IR Temperature Sensor For Arduino (MLX90614-DCC)
$18.50
SKU: SEN0206
  • $17.90 3+ items
  • $17.50 5+ items
  • $17.00 10+ items
The MLX90614 infrared temperature module offers non-contact, accurate readings via infrared radiation, suitable for medical and commercial uses.
Purchase this product and earn 185 reward points, which are tied to VIP membership program. Learn More >
We can divide temperature measurement in to two types: contact and non-contact. Contact measurement can only accurately measure temperature when the testing object and the sensor reach thermal equilibrium. This can mean longer response times and reading inaccuracies offset by ambient temperature. By contrast, non-contact measurement uses infra-red radiation to measure the temperature and does not require a direct touch. Additionally, this method of measurement can be read quickly and accurately.
In recent years non-contact measurement methods have been used for medical, environmental monitoring, home automation, automotive electronic, aerospace, and military applications.
Our latest infrared temperature measurement module is the MLX90614. This module measures the surface temperature by detecting infrared radiation energy and wavelength distribution. The IR temperature probe consists of an optical system, photoelectric detector, amplifier, signal processing, and output module. The optical system collects the infrared radiation in its field of view and the infrared radiation energy is converted in to corresponding electrical signals when converging on the photoelectric detector. After being processed by the amplifier and signal processing circuit, the signal is converted in to a temperature value. The MLX90614 is self calibrating and has a low noise amplifier integrated in to the signal processing chip. The chip itself is a 17 bit ADC and DSP device, giving accurate and reliable results.
Gravity: I2C Non-contact IR Temperature Sensor Arduino Selection Form
Note: The MLX90614 offers a standard accuracy of ±0.5˚C around room temperatures, while the medical-grade MLX90614 offers an accuracy of ±0.2˚C in a limited temperature range around the human body temperature.
Gravity: I2C Non-contact IR Temperature Sensor For Arduino (MLX90614-DCC), due to its large field of view (FOV = 35°), is more suitable for commercial application. We recommand Gravity: I2C Non-contact IR Temperature Sensor (MLX90614-DCI) for industrial applications. It has a longer distance range.
  • Model: MLX90614-DCC
  • Operating Voltage: 3.3V - 5V
  • Measurement Accuracy: ±0.2℃(body temperature range)/ ±0.5℃
  • Temperature: -70.01℃ to +380℃, (0.01 ℃ resolution)
  • Interface Type: I2C
  • Interface Line Sequence: VCC, GND, SCL, SDA
  • FOV: 35°
  • Dimensions: 31.5*18 mm/1.24 x 0.7 inches
  • Weight: 15g
  • on-contact IR Thermometer Sensor x1
  • JST PH2.0 4-Pin cable x1
Jul 27, 2017
Making a Temperature-Detecting 'Portal Gun' with Unihiker
Projects Making a Temperature-Detecting 'Portal Gun' with Unihiker
Afra
Nov 22, 2023
Steffen.Lorenz Nov 27, 2024
Very good product! Easy to connect and use. I can recommend.
Chih.Kuo Jan 03, 2022
good product
Chih.Kuo Dec 01, 2021
Excellent product
