Gravity: Bright LED Module
$2.50
SKU: DFR0438
  • $2.38 5+ items
  • $2.25 10+ items
  • $2.00 50+ items
Bright LED module for special applications, using a gravity 3-pin interface. Requires 5VDC and 20mA. Includes LED module and cable. Avoid staring directly at LED.
The Bright LED module is designed for some special application. It's using a very bright LED component as its light source. Compatible with DFRobot gravity 3-Pin interface, plug and play. What you need is just a digital signal, you can drive it directly. Besides, the LED is so bright that do not stare at the LED in case of any eye damaging!
Project 1: Annoying Soil Moisture Sensor with Photon and IFTTT Project
Never forget to water your plants again with this super annoying project. It combines visual, auditory, and textual cues that will prevent you from doing anything else until you provide your plant with much-needed hydration. A piezo buzzer constantly blares a shrill note, while a super-bright LED annoys your peripheral vision. In addition, this project will send constant texts to your phone reminding you that your plant needs to be watered. Sounds like fun, right?
Hardware Components:
  • Operating Voltage: 5VDC
  • Opearting Current: 20mA (Max)
  • Dimension: 30*22(mm)/ 1.18”*0.87”(in)
  • Bright LED Module x1
  • Gravity 3-Pin Cable x1
Best Collection of 10 micro:bit Robot and IoT Projects to Try in 2023
Projects Best Collection of 10 micro:bit Robot and IoT Projects to Try in 2023
RiverTrue
Nov 08, 2024
Danli
Jan 10, 2024
Iñaki.Garcia Vicen May 14, 2025
Buena iluminación y bajo consumo
