Aluminum Heatsink Cooling Fan for LattePanda V1
$12.00
SKU: FIT0504
  • $11.60 3+ items
  • $11.40 5+ items
  • $11.00 10+ items
Ultra low noise fan with aluminum heat sink for stable cooling of LattePanda V1. Easy 2-Pin connection; not compatible with Alpha & Delta models.
Purchase this product and earn 120 reward points, which are tied to VIP membership program. Learn More >
The low profile ultra low noise fan keeps your LattePanda running at a stable temperature. The 2-Pin jumper connector makes it easily to connect with the CN2 headers on the board.
The aluminum heat sink includes an adhesive thermal pad on the rear that can stick on the metal shield on the board. With its aluminum casing, heat from CPU will be absorbed fast, giving you the best performance. This is a simple and effective way to keep your Lattepanda V1 (win10 mini pc) cool! (not compatible with LattePanda Alpha & Delta)
Note: Please pay attention to wire polarities
Red - 5V
Black - GND
What is a LattePanda?
A LattePanda is a complete Windows 10 single board computer! It includes everything a regular PC has and can do anything that a regular PC does. It is compatible with almost every gadget you know: printers, joysticks, cameras and more. Any peripherals that work on your PC will work on a LattePanda. A LattePanda comes pre-installed with a full, pre-activated version of Windows 10, where you can install powerful tools such as Visual Studio, NodeJS, Java, Processing, and more. Using existing APIs, you can develop your own software and hardware projects on a LattePanda as you would on a normal PC - C#, Javascript, Ruby and so on. Say goodbye to your bulky laptop!
  • Operating Voltage: 5v
  • Operating Current: 0.14A
  • Rated Speed: 7500 RPM
  • Cable Length: 18cm
  • Interface Type: 2.54mm 2-Pin DuPont Female Connector
  • Dimensions: 35 x 35 x 10 mm/1.38 x 1.38 x 0.39"
  • Fan Dimensions: 30 x 30 x 7 mm/1.18 x 1.18 x 0.28"
  • Weight: 14g
  • LattePanda Alpha & Delta is not compatible
    • Aluminum Case Cooling Fan x 1
    Virtual Physical Combo Organ
    Projects Virtual Physical Combo Organ
    Hackster.io
    Nov 16, 2021
    DIY A Steampunk Computer
    Blog DIY A Steampunk Computer
    Oct 31, 2016
    ROMBUS PINBALL - A LATTEPANDA MINI PINBALL MACHINE
    Blog ROMBUS PINBALL - A LATTEPANDA MINI PINBALL MACHINE
    May 18, 2018
    RiverTrue
    Jan 23, 2025
    Sebastian.Adonay Oct 17, 2021
    Makes my LattePanda run cool even with sun exposition, near the windows of the lab. No thermal throttling!
    Pasan.Dharmasiri Mar 23, 2026
    Very Good product and fast shipping
    Dawn.Fochi Mar 07, 2025
    Product works great for our access computer application for cooling
    Only 12 Left
