Note: Please pay attention to wire polarities
Red - 5V
Black - GND
What is a LattePanda?
A LattePanda is a complete Windows 10 single board computer! It includes everything a regular PC has and can do anything that a regular PC does. It is compatible with almost every gadget you know: printers, joysticks, cameras and more. Any peripherals that work on your PC will work on a LattePanda. A LattePanda comes pre-installed with a full, pre-activated version of Windows 10, where you can install powerful tools such as Visual Studio, NodeJS, Java, Processing, and more. Using existing APIs, you can develop your own software and hardware projects on a LattePanda as you would on a normal PC - C#, Javascript, Ruby and so on. Say goodbye to your bulky laptop!
Oct 17, 2021
Makes my LattePanda run cool even with sun exposition, near the windows of the lab. No thermal throttling!
Mar 07, 2025
Product works great for our access computer application for cooling
Apr 21, 2021
Works well with Lattepanda, a little noisy, but if you add a temperature sensor, some motor control circuitry and some code to the arduino, then you have a small temperature controlled fan :)
