Gravity: Vibration Motor Module For Arduino
$2.50
SKU: DFR0440
  • $2.30 10+ items
  • $2.00 50+ items
A coin-sized vibration motor module compatible with Arduino and Raspberry Pi. Ideal for projects like alarms and wearables, with easy plug-and-play features.
Have you ever wondered how to implement a vibration motor in your project, like you would find in a mobile phone? The latest vibration module in the DFRobot "Gravity" series will give you in-depth understanding of the principles of vibration motors. This module uses a high quality vibration motor that is the size of a coin. With this little vibration motor module, you can make some interesting Arduino projects such as an alarm, a notifier or even a vibrating robot!
Gravity: Arduino Vibration Motor Module Diagram
To make this sensor accessible to users of all backgrounds, a three pin Gravity interface is connected to allow plug and play usage with a range of Arduino microcontrollers. The I/O sensor shield is also a useful accessory and will allow you to connect directly to your Arduino. This sensor can also work at 3.3V levels which makes it compatible with Raspberry Pi, Intel Edison, Joule and Curie.
Project 1. How to Make a Running Heart Alarm T-shirt
A DIY heart-rate wereable in a running t-shirt that vibrates when your heart-rate is high, using DFROBOT components:
Component List:
Arduino Nano
vibration motor module for arduino
beetle- the smallest arduino
heart rate monitor sensor arduino
  • Operating Voltage: 5V
  • Control Mode: High-Low level / PWM signal
  • Dimensions: 30 x 22 mm / 1.18 x 0.78"
  • Gravity: Vibration Module x 1
  • Gravity Series PH2.0 to XH2.54 3 Pin Digital Cable x 1
    Ionizing Radiation Detector
    Projects Ionizing Radiation Detector
    KGray
    Jun 25, 2024
    Universite Laval GMC.Pavillon Pouliot Oct 31, 2025
    excellent product!!!
    Ayaz.Ahmed May 17, 2025
    Attached connector and PCB make it bigger but motor is strong.
    Steffen.Lorenz Dec 31, 2024
    It just works as expected :)
