Note: Use the provided adapter to power the string to avoid the risk of damage.
This item uses a Gravity interface for plug-and-play usage. Use an Arduino IO Expansion Shield for a convenient solution to connect to your Arduino. This sensor works at 3.3V, making it compatible with Raspberry Pi, Intel Edison, Intel Joule, and Intel Curie.
