Gravity: Digital LED String Lights (Warm White) For Arduino
$9.90
SKU: DFR0448
Warm white LED string lights for decoration, compatible with Arduino and Raspberry Pi. Operates at 2.5-5V. Includes adapter and digital cable. 4 meters long.
These LED string lights are composed of a series of warm white LEDs that can be used for decoration or other interesting applications. Use them as outdoor string lights, string lights in your bedroom, on your patio, or on a globe, and even as Christmas lights. Create a fading effect using PWM or power them at a fixed voltage.
Note: Use the provided adapter to power the string to avoid the risk of damage.
This item uses a Gravity interface for plug-and-play usage. Use an Arduino IO Expansion Shield for a convenient solution to connect to your Arduino. This sensor works at 3.3V, making it compatible with Raspberry Pi, Intel Edison, Intel Joule, and Intel Curie.
  • Operating Voltage: 2.5 ~ 5V (5V Recommended)
  • LED Length: 4 meters/40 LEDs
  • Adapter Dimensions: 30 x 22 mm/1.18 x 0.86"
  • Weight: 26g
  • Gravity: LED String Lights (Warm White) x1
  • LED String Lights Adapter x1
  • Gravity Digital Cable x1
  • Only 9 Left
