8x8 RGB LED Matrix
$25.00
SKU: DFR0459
8x8 RGB LED Matrix with WS2812 LEDs, supports cascading control and Arduino integration. Requires 5V power and external supply for multiple use.
Purchase this product and earn 250 reward points, which are tied to VIP membership program. Learn More >
8x8 RGB LED Matrix is a compact full‑color LED display panel built around WS2812 intelligent LEDs, delivering vibrant programmable lighting for interactive electronics and creative embedded projects. The square illumination board integrates 64 individually addressable RGB pixels arranged in an 8×8 grid and connected through an XH2.54 3‑pin interface. Each pixel supports precise digital control with up to 256 brightness levels per color channel, producing a palette of 16,777,216 colors. Combined with simple single‑wire communication and compatibility with Arduino, this programmable LED matrix panel enables dynamic animations, visual indicators, and colorful graphical effects in robotics, IoT prototypes, and electronic art installations.
Note: Each LED requires a maximum current of 18mA. When multiple modules are connected together, using an external power supply is recommended to ensure stable operation of multiple LED matrices.
Individually Addressable WS2812 RGB Pixels
Each LED in the 8×8 grid functions as an independently addressable RGB pixel driven by integrated WS2812 control circuitry. This intelligent lighting architecture allows precise control of color and brightness for every LED, supporting 256 brightness levels per channel and a total of 16.7 million color combinations. A scanning frequency of at least 400Hz ensures smooth visual output, making the addressable LED display board suitable for animated icons, scrolling patterns, status indicators, and decorative lighting effects.
Single‑Wire Data Control Architecture
The programmable RGB lighting board uses a streamlined single‑wire communication protocol, allowing complex lighting patterns to be controlled through only one digital signal pin. The simplified interface significantly reduces microcontroller pin usage while maintaining precise timing control for each LED. Combined with open‑source libraries and widely supported microcontroller platforms, this intelligent LED panel becomes an efficient visual output device for embedded systems and rapid prototyping projects.
Cascadable Design for Larger Displays
The addressable LED matrix supports cascade connection through DIN and DOUT signal lines, enabling multiple modules to form larger programmable displays. Expanding the lighting array requires only linking the output of one panel to the input of the next. This scalable architecture makes the RGB LED matrix suitable for building extended visual displays, programmable lighting walls, or larger animated panels without increasing microcontroller pin requirements.
Applications include robotics status displays, programmable lighting effects, interactive art installations, embedded user interfaces, and educational electronics demonstrations. The compact RGB matrix module provides a flexible visual output solution for makers, engineers, and STEM Education projects requiring colorful digital feedback or animated graphics.
  • Full color RGB LED matrix with individually addressable pixels
  • Supports cascading connection for expanded LED arrays
  • Compatible with external power supply for multi‑module setups
  • Programmable LED displays
  • Robotics visual indicators
  • Interactive electronic art
  • IoT device status panels
  • STEM Education electronics projects
  • Operating Voltage: 5V
  • LED Type: WS2812
  • Communication Interface: XH2.54 3Pin
  • Operating Temperature: -25 ~ +80 ℃
  • Dimension: 65 * 65 mm / 2.56 * 2.56 inches
  • Weight: 22g
  • 8x8 RGB LED Matrix ×1
  • XH2.54-3Pin Pin Header ×1
  • Only 7 Left
    8x8 RGB LED Matrix
