Gravity: Sensor Cable For LattePanda V1 (10 Pack)
$6.00
SKU: FIT0514
A 10-pack of Gravity sensor cables designed for LattePanda V1 and DFRobot Gravity sensors. Features anti-reverse-polarity connectors, KF2510-3P to PH2.0-3P wiring, 20cm length, rated up to 50V and 1000mA.
Purchase this product and earn 60 reward points, which are tied to VIP membership program. Learn More >
This Gravity sensor cable pack provides a reliable and foolproof wiring solution for connecting sensors and actuators to the LattePanda V1 platform. Specially engineered for LattePanda V1 and DFRobot Gravity sensors, each cable features a KF2510-3P connector on one end and a PH2.0-3P connector on the other, with a standardized color-coded wire layout. Ten cables are included per pack, offering ample supply for multi-sensor projects and reducing the need for repeated reordering during active development.
Anti-Reverse-Polarity Design for Safe and Confident Connections
Each cable in this pack features an anti-reverse-polarity connector design that physically prevents incorrect insertion, eliminating the risk of miswiring sensors or actuators to the LattePanda V1. This keyed connection mechanism is especially valuable during rapid prototyping sessions where multiple sensors are being connected simultaneously. Combined with a clear color-coded scheme — red for power, black for ground, and orange for signal — wiring becomes fast, intuitive, and error-resistant even for first-time users working with embedded sensor systems.
Purpose-Built Compatibility with LattePanda V1 and Gravity Sensors
This cable is specifically designed for use with LattePanda V1 and is not compatible with LattePanda Alpha or Delta variants. The dual-connector configuration bridges the KF2510-3P interface on LattePanda V1 with the PH2.0-3P interface standard used across the wide DFRobot Gravity sensor ecosystem. At 20cm in length, each cable provides sufficient reach for clean board-to-sensor routing within typical enclosures and project builds, while the electrical ratings of under 50V and under 1000mA cover the full operating range of standard Gravity sensor modules.
From multi-sensor environmental monitoring setups and robotics builds to interactive installations and embedded computing projects, this Gravity sensor cable pack simplifies wiring and accelerates assembly. The inclusion of ten cables per pack ensures full coverage for complex multi-point sensor layouts on LattePanda V1-based platforms.
Wiring Diagram of cable and lattepanda v1
  • Specifically designed for LattePanda V1 and DFRobot Gravity sensors
  • Anti-reverse-polarity connector design prevents incorrect insertion
  • KF2510-3P to PH2.0-3P dual-connector configuration
  • Color-coded wiring: Red (PWR), Black (GND), Orange (Signal)
  • 20cm cable length for clean and flexible routing
  • Rated up to 50V and 1000mA for full Gravity sensor compatibility
  • 10 cables included per pack for multi-sensor project builds
  • Not compatible with LattePanda Alpha or Delta
  • Connecting Gravity sensors to LattePanda V1 boards
  • Multi-sensor environmental monitoring systems
  • Robotics and motion control wiring
  • Embedded computing and single-board computer projects
  • Interactive installations with sensor-driven inputs
  • Rapid prototyping with DFRobot Gravity sensor modules
  • Length: 20cm (8 in)
  • Maximum voltage: <50V
  • Maximum current: <1000mA
  • One KF2510-3P connector
  • One PH2.0-3P connector
  • Red: PWR; Black: GND; Orange: Signal
  • Gravity sensor cable for LattePanda x10
  • FAQ
    Sebastian.Adonay Oct 17, 2021
    Makes prototyping way easier and faster.
    Dantes. Nov 19, 2021
    As advertised.
    Renji.abraham Oct 15, 2021
    Great Product
    Only 12 Left
