The DFRobot DF9GMS is a 360 degree micro servo. It uses a plastic gear drive and is light and compact. It can be used for
various applications and DIY products, such as toy cars, boats, windmills etc.
A 360 degree servo’s operation is more similar to a DC motor than a standard servo as only rotation direction and speed can be controlled. There is also no hardware stop inside so that the shaft can rotate freely. Compared to an ordinary DC motor, a 360-degree servo motor does not require additional motor drivers and is plug and play, compact and convenient. Arduino control methods are also the same. When the servo is operating on the 4.8 ~ 6V power supply, the torque can reach 1.2 ~ 1.6Kg x cm
Note: This is a continuous rotation servo. It cannot be commanded to specific angles like standard 180° servos.
Apr 05, 2025
nice and small, not the simplest to use but still kinda plug and play
May 10, 2023
Very fast shipping. Thanks!
