This is an industrial incremental photoelectric rotary encoder with aluminum material, metal shell and stainless steel shaft. It generates AB two-phase orthogonal pulse signal though the rotation of the grating disk and optocoupler. 400 pulses/round for each phase, and 1600 pulses/round for dual-phase 4 times output. This rotary encoder supports max 5000 r/min speed. And it can be used for speed, angle, angular velocity and other data measurement.
The photoelectric rotary encoder has a NPN open collector output. It could work with Microcontroller with internal pull-up resistors directly.
Note: NPN open collector output needs pull-up resistors for the oscilloscope display.
Supply Voltage: 5V
Encoder Body Size: Φ39× 36.5mm
Output Shaft Diameter: Φ6 × 13mm
Outside Shaft Platform: Φ20 × 4.85 mm
Fixing Holes Screws: M3
Weight: 234 g
Encoder x1
Encoder mounting bracket x1
6mm coupling x1
Screw accessories x1
10K resistance x2
