Realtek Ameba-RTL8195AM WiFi & NFC Module integrates wireless connectivity, NFC capability, and a 32‑bit ARM Cortex‑M3 microcontroller into a compact IoT development platform. This connectivity-focused embedded module combines Wi‑Fi networking, NFC communication, and multiple high‑speed peripheral interfaces for rapid prototyping of smart devices. Designed for IoT gateways, wireless control systems, and networked sensors, the Realtek-based solution provides USB 2.0 host/device, SDIO, and Ethernet connectivity alongside rich GPIO expansion. Compatibility with Arduino development tools and MicroPython environments simplifies firmware development for connected hardware projects and embedded networking applications.
Note: RTL8195AM targets developers and several functions remain under testing. Refer to the official resources for detailed implementation information.
Integrated Wi‑Fi, NFC, and Microcontroller Architecture
Realtek’s embedded networking chip merges wireless connectivity and processing resources into a single compact module. The hardware platform integrates 802.11 b/g/n Wi‑Fi capability with NFC read/write functionality and a 166MHz ARM Cortex‑M3 MCU. Combined connectivity enables wireless identification, short‑range communication, and internet access within the same hardware design. Built‑in Ethernet support and compatibility with IoT infrastructure allow rapid deployment of connected products, smart appliances, and network-enabled embedded systems.
Rich High‑Speed Interfaces for Embedded Systems
This IoT networking module offers extensive peripheral connectivity for advanced embedded designs. High‑speed interfaces include USB 2.0 host/device, SDMMC HS, SDIO device, and MII/RMII Ethernet communication. Additional digital and analog interfaces—SPI, I2C, UART, ADC, DAC, PWM, and I2S/PCM—enable integration with sensors, storage devices, and control electronics. Up to 30 configurable GPIO pins support flexible hardware expansion, allowing the compact networking controller to serve as the core communication engine for smart gateways, data acquisition nodes, and automation controllers.
Stable Networking Solution from a Leading Wi‑Fi Supplier
Realtek ranks among the largest global suppliers of wireless networking chipsets, bringing proven stability and reliability to embedded IoT deployments. The RTL8195AM platform combines low‑power operation with secure connectivity through a hardware SSL engine. Integrated Ethernet and NFC support expand connectivity options beyond typical Wi‑Fi microcontrollers, creating a versatile communication platform suitable for industrial prototypes, smart device networking, and experimental IoT infrastructure.
Applications include connected sensor nodes, smart access systems using NFC identification, wireless monitoring devices, and compact IoT gateways. The Realtek networking module provides developers with a reliable hardware foundation for building Wi‑Fi connected electronics, edge computing prototypes, and embedded networking solutions across education, research, and product development.
