Metal DC Geared Motor w/Encoder - 6V 210RPM 10Kg.cm
$19.90
SKU: FIT0521
6V metal geared DC motor with encoder, 34:1 gearbox, and 341.2 PPR. Ideal for robots. Specs: 210RPM, 10kg·cm torque, dimensions 52x24.4mm, weight 96g.
This is a metal geared DC motor w/Encoder. It is a 6V motor with a 34:1 metal gearbox and an integrated quadrature encoder that provides a resolution of 11 counts per revolution of the motor shaft, which corresponds to 341.2 counts per revolution of the gearbox’s output shaft.
Metal DC Geared Motor Pinmap
Pinmap
These units have an 8 mm length, 4 mm-diameter D-shaped output shaft. This motor is intended for use at 6V, though the motor can begin rotating at voltages as low as 1V. This motor is an ideal option for your mobile robot project.
Metal DC Geared Motor Dimension
Dimension
  • Motor Rated Voltage: 6V
  • Encoder Rated Voltage: 3.3 / 5V
  • Reducer Reduction Ratio: 1: 34
  • No load Speed: [email protected]
  • Maximum Efficiency Point: load 2.0kg·cm/170RPM/2.0W/0.6A
  • Maximum Power point: Load 5.2kg·cm/110RPM/3.1W/1.1A
  • Stall Torque: 10kg·cm
  • Stall Current: 3.2A
  • Hall Resolution: Hall Resolution 11x Precision Reduction Ratio 34.02 = 341.2PPR
  • Dimension: 52 * Φ24.4 mm / 2.05 * Φ0.96inches
  • Weight: 96g
  • Metal DC Geared Motor w/Encoder - 6V 210RPM 10Kg.cm x1
  • JST 6-Pin cable x1
