OpenMV Cam H7 – A Machine Vision Camera (Discontinued)
SKU: DFR0517
Discontinued
Note: OpenMV Cam H7 – A Machine Vision Camera is discontinued now, we recommend OpenMV Cam RT1060 Camera for Machine Vision as a suitable replacement.
The OpenMV Cam H7 comes with a MT9M114 image sensor is capable of taking 640x480 8-bit Grayscale images or 640x480 8-bit BAYER images at 40 FPS when the resolution is above 320x240 and 80 FPS when it is below. Most simple algorithms will run between 40-80 FPS on QVGA (320x240) resolutions and below. Your image sensor comes with a 2.1mm lens on a standard M12 lens mount. If you want to use more specialized lenses with your image sensor you can easily buy and attach them yourself.
The STM32H743VI ARM Cortex M7 processor running at 480 MHz with 1MB SRAM and 2MB of flash. All I/O pins output 3.3V and are 5V tolerant. The processor has the following I/O interfaces:
  • A full speed USB (12Mbs) interface to your computer. Your OpenMV Cam will appear as a Virtual COM Port and a USB Flash Drive when plugged in.
  • A μSD Card socket capable of 100Mbs reads/writes which allows your OpenMV Cam to take pictures and easily pull machine vision assets off of the μSD card.
  • A SPI bus that can run up to 80Mbs allowing you to easily stream image data off the system to either the LCD Shield, the WiFi Shield, or another microcontroller.
  • An I2C Bus (up to 1Mb/s), CAN Bus (up to 1Mb/s), and an Asynchronous Serial Bus (TX/RX, up to 7.5Mb/s) for interfacing with other microcontrollers and sensors.
  • A 12-bit ADC and a 12-bit DAC.
  • Three I/O pins for servo control.
  • Interrupts and PWM on all I/O pins (there are 10 I/O pins on the board).
  • An RGB LED and two high power 850nm IR LEDs.
    The OpenMV Cam can be used for the following things currently (more in the future):
  • Frame Differencing
  • Color Tracking
  • Marker Tracking
  • Face Detection
  • Eye Tracking
  • Optical Flow
  • QR Code Detection/Decoding
  • Data Matrix Detection/Decoding
  • Linear Barcode Decoding
  • AprilTag Tracking
  • Line Detection
  • Circle Detection
  • Rectangle Detection
  • Template Matching
  • Image Capture
  • Video Recording
    Processor ARM® 32-bit Cortex®-M7 CPU
    w/ Double Precision FPU
    480 MHz (1027 DMIPS)
    Core Mark Score: 2400
    (compare w/ Raspberry Pi 2: 2340)
    RAM Layout 64KB Stack
    256KB .DATA/.BSS/Heap
    512KB Frame Buffer/Stack
    256KB DMA Buffers
    Flash Layout 128KB Bootloader
    128KB Embedded Flash Drive
    1792KB Firmware
    (2MB Total)
    Supported Image Formats Grayscale
    RGB565
    JPEG (and BAYER)
    Maximum Supported Resolutions Grayscale: 640x480 and under
    RGB565: 320x240 and under
    Grayscale JPEG: 640x480 and under
    RGB565 JPEG: 640x480 and under
    Lens Info Focal Length: 2.1mm
    Aperture: F2.0
    Format: 1/6"
    HFOV = 60.7°, VFOV = 47.5°
    Mount: M12*0.5
    IR Cut Filter: 650nm (removable)
    Electrical Info All pins are 5V tolerant with 3.3V output. All pins can sink or source up to 25mA. P6 is not 5V tolerant in ADC or DAC mode. Up to 120mA may be sinked or sourced in total between all pins. VIN may be between 3.6V and 5V. Do not draw more than 250mA from your OpenMV Cam's 3.3V rail.
    Weight 19g
    Length 45mm
    Width 36mm
    Height 30mm
  • OpenMV Cam H7 x1
  • Pin Header x2
  • FAQ
