Note: The fan will be damaged when the polarity is reversed.
This aluminum alloy case is a solid enclosure for LattePanda single board computer V1.0 (not compatible with LattePanda Alpha & Delta). It adopts to CNC machining and manufacturing, anodic oxidation surface treatment process. The inner space is enough to mount cooling fan (the total thickness of fan should be less than 7.7mm). And the vent and connection hole are all reserved to mount touch panel, display and cooling fan.
What is LattePanda?
A LattePanda is a complete Windows 10 single board computer. It has everything a regular PC has and can do anything that a regular PC does. It is compatible with almost every gadget you know: printers, joysticks, cameras and more. Any peripherals that work on your PC will work on a LattePanda.
