10.1" 1200×1920 IPS Display for LattePanda V1 delivers a compact high‑resolution visual interface tailored for Windows‑based embedded computing. Designed specifically for integration with LattePanda single‑board computers, this 10.1‑inch IPS panel enables the creation of sleek all‑in‑one systems such as portable tablets, robotics interfaces, infotainment consoles, and industrial control displays. The high‑density 224 PPI panel produces crisp text and vivid graphics, while the direct FPC connection simplifies integration by combining power and signal through a single cable. Such streamlined hardware design frees the HDMI port for additional displays, enabling flexible dual‑screen embedded setups.
Figure: 10.1 inch 1200×1920 IPS display for LattePanda V1
Note: LattePanda board and power supply are not included. A 5V@3A power supply is required when driving LattePanda together with this display. Default orientation is portrait mode and system rotation may be configured in the operating system. Compatibility excludes LattePanda Z8300 CR110 boards as well as LattePanda Alpha and Delta editions.
High‑Density 224 PPI IPS Visual Performance
This 10.1‑inch WUXGA IPS screen provides a resolution of 1200×1920, delivering sharp text and detailed graphics comparable to printed material. The TFT‑LCD panel technology offers wide viewing angles and stable color reproduction, making the embedded display module suitable for graphical user interfaces, data dashboards, and multimedia applications. High pixel density enhances readability for coding environments, Windows applications, and industrial visualization tasks where clarity and precision are essential.
Single‑Cable Integration via MIPI‑DSI
The embedded display panel connects directly through an FPC cable that carries both power and video signals through the MIPI‑DSI interface. Such streamlined connectivity removes the need for additional adapter boards, reducing wiring complexity and improving system reliability. A direct connection architecture also leaves the HDMI port available for a secondary monitor, supporting dual‑display configurations in compact embedded computing projects.
Designed for Compact Embedded Systems
The slim 2.2 mm display module and lightweight 190 g structure enable seamless integration into portable electronics, robotics platforms, and custom enclosures. The portrait‑oriented screen layout fits naturally into tablet‑style interfaces, handheld controllers, and vertical information panels. Such versatility allows developers to create interactive robotics faces, portable control terminals, and integrated computing devices without adding bulky display hardware.
This high‑resolution embedded screen module serves applications including portable Windows tablets, robotics user interfaces, smart kiosks, infotainment terminals, and interactive maker projects. Combined with LattePanda computing boards, the compact display solution enables visually rich human‑machine interfaces for prototyping, product development, and STEM Education environments.
