Fermion: TB6612FNG 2x1.2A DC Motor Driver (Breakout)
$4.50
SKU: DRI0044
  • $4.40 2+ items
  • $4.20 5+ items
  • $4.00 10+ items
A micro dual-way DC motor driver uses TB6612FNG IC, requiring four pins to drive two motors. Compatible with L298N code, it suits DIY projects and Arduino.
This DFRobot micro dual way DC motor driver is design based on TB6612FNG motor driver IC. It inherits DFRobot L298N motor control logic, which only need four pins to drive 2 motors. Compared with the IC Breakout, it saves two precious GPIO resource, especially in Arduino UNO board.
TB612FNG is a dual-channel full-bridge drive chip. The maximum continuous drive current of single channel can reach 1.2A, peak value 2A/3.2A (continuous pulse / single pulse) , which can drive some micro DC motors. The control logic is similar to L298n, and the code can be directly compatible with the DFROBOT L298N motor driver. Standard XH2.54 pin can be inserted directly into the breadboard. It is a good choice for DIY project or product developments.
How To Make DIY Arduino Metal Detector Robot At Home
  • VCC Operating Voltage: 2.7V~5.5V
  • VM Input Power: 2.5V~12V
  • Driver Channel: 2 channel
  • Output Current: 1.2A (single-channel continuous drive current)
  • Start / Peak Current: 2A (continuous pulse) / 3.2A (single pulse)
  • Dimension: 0.79 x 0.77(in) / 20 x 19.50(mm)
  • 2x1.2A DC Motor Driver (TB6612FNG) x1
  • XH2.54-6Pin x2
    MiniQ robot chassis. Dfrobot.com
    Media MiniQ robot chassis. Dfrobot.com
    Home Made
    Apr 23, 2020
    MiniQ Robot chassis Encoder. Dfrobot.com
    Media MiniQ Robot chassis Encoder. Dfrobot.com
    Home Made
    Apr 22, 2020
    Motor driver. Dfrobot.com
    Media Motor driver. Dfrobot.com
    Home Made - То, что ты можешь сделать
    Apr 11, 2020
    Make Your Own Arduino Desktop Self-Balancing Robot
    Blog Make Your Own Arduino Desktop Self-Balancing Robot
    Jul 05, 2018
    kyle.benson Oct 12, 2023
    Works well for small projects. Thanks!
