The Solar Power Manager is a high-efficiency module for IoT and renewable energy projects, offering MPPT function, multi-voltage outputs, and various protections.
Purchase this product and earn 389 reward points, which are tied to VIP membership program.
Learn More >
The DFRobot Solar Power Manager series are designed for IoT projects and renewable energy projects, providing safe and high-efficiency embedded solar power management modules for makers and application engineers.
Solar Power Manager is a complete small power and high-efficiency solar power management module. It features as MPPT (Maximum Power Point Tracking) function, maximizing the efficiency of the solar panel. Apart from serving as a solar charger, the module can provide up to 2A charging current to 3.7V Li battery with AC adapter (within 30V) or USB charger, three individual ON/OFF controllable DC-DC converters with 5V 1.5A, 3.3V 1A and 9V/12V 0.5A outputs. These features satisfy the needs of
various solar power projects and low-power applications. The module also employs various protect functions, such as Li battery protection, battery/solar panel reverse connection protection, output over temperature and over current/short circuit protection, which greatly improves the stability and safety of the system.
Over Charge/Over Discharge/Over Current/Reverse Connection Protections
Over Charge/Over Discharge/Reverse Connection Protections
Output Protections
Short Circuit/Over Current Protections
Short Circuit/Over Current/Over Heat Protections
USB Charge IN
Yes
Yes
No
Yes
USB OUT
5V 1A
5V 1.5A
5V 2.5A x2
No
Regulated OUT
One Regulated Output 5V 1A
Three Regulated Outputs 3.3V 1A;5V 1.5A;9V/12V 0.5A
Two Outputs 5V 5A; 12V 8A
One Regulated Output 3.3V 90mA
Dimension
33.0mm×63.0mm
78.0mm×68.0mm
68.0mm×68.0mm
30.0mm×30.0mm
A small and easy-to-use 5V solar power management module.
Applications: Solar Power Bank, Solar Environment Monitors
For 5V Solar Panels within 10W
A complete multifunction solar power management module.
Applications: Small Solar Street Lamp, Solar Powered Robots
For 9V/12V/18V Solar Panels within20w
A medium power solar management module for 12V lead-acid batteries.
Applications: Street lighting, intelligent agriculture, environmental monitoring station, UPS
For 18V Solar Panels within 100W
A micro power solar power management module for low-power sensors and controllers.
Applications: Wireless Sensor Network, BLE iBecon
For 1V/2V/3V Solar Panels within 0.5W
Add to Cart
Constant voltage MPPT algorithm, maximizing solar panel efficiency
7V~30V wide solar panel input voltage
Various charging mode: solar/AC adapter/USB charger (2A max charge current)
Three individual ON/OFF controllable regulated power supply for low-power applications
All multi-layer ceramic capacitors (MLCC), safe, stable and high-efficiency
Various protection functions
USB connector with ESD shell
Smart solar environment monitor system
Solar powered robot
Small solar street lamp
Solar power bank
Solar power management IC: LTC3652
Solar input voltage (SOLAR IN): 7V~30V
Battery input (BAT IN): 3.7V single cell Li-polymer/Li-ion battery
Charge current(USB/SOLAR IN): 2A Max
Charging cutoff voltage(USB/SOLAR IN): 4.2V±1%
MPPT setting voltages:OFF/9V/12V/18V
USB IN voltage: 5V
Regulated power supply: OUT1=5V 1.5A; OUT2=3.3V 1A; OUT3=9V/12V 0.5A
