The BMI160 6-axis inertial motion sensor is a new product from DFRobot. It is based on Bosch BMI160 6-axis MEMS sensor which integrates 16-bit 3-axis accelerometer with ultra-low-power 3-axis gyroscope. Bosch BMI160 is designed for smartphones, tablets, wearable devices. It has built-in intelligent step-counting algorithms that can be read directly through registers. Built-in 3-axis acceleration and 3-axis gyroscope can detect running, fitness and other motion. Built-in LDO power management chip, supports 3.2~6V wide voltage power supply, and also has I2C level conversion circuit, compatible with Arduino 3.3V and 5V micro controller.
Step Count
Acceleration Detection
Inclination Measurement
Display Toggle Horizontal / Vertical Mode
Operating Voltage: 3.2V~6V
Current Consumption: <1mA
Interface: Gravity-I2C
Acceleration Range: ±2g/±4g/±8g/±16g
Gyroscopes Range: ±125°/s,±250°/s,±500°/s,±1000°/s,±2000°/s
Acceleration Zero-g Offset: ±40mg
Gyroscopes Zero-g Offset: ±10°/s
Programmable Frequency: 25/32Hz~1600Hz
6D Detection and Location
16-bit Data Output
Shock Resistance: 1000gx 200us
2 Independent Programmable Interrupt Generators
In-built 1024 Byte FIFO
Working Temperature:-40℃~+85℃
Dimension: 22X27mm/0.87x1.06 in
Gravity: I2C BMI160 6-axis IMU x1
Gravity I2C/UART sensor cable x1
XH2.54 Single Row Pin Header-4P x1
Projects Acelerómetro y Giroscópio
Sergio A. Castaño Giraldo Jul 19, 2021 Projects Live Sailboat Monitoring over LoRa
