Gravity: I2C 12-Bit DAC Module
$4.90
SKU: DFR0552
  • $4.69 3+ items
  • $4.49 5+ items
  • $4.19 10+ items
12-bit I2C DAC with EEPROM ensures precise digital-to-analog conversion. Supports 3.3V-5V input and functions in control systems or as a waveform generator.
DFRobot Gravity 12-Bit I2C DAC is a small and easy-to-use 12-bit digital-to-analog converter with EEPROM. It can accurately convert the digital value to corresponding analog voltage signal, which is useful in may creative projects and automatic control systems. Although an analog voltage signal can be generated by PWM with traditional controllers such as Arduino and Raspberry Pi, such signal is ROUGH and NOT ACCURATE. To obtain a steady and nice analog voltage signal, the DAC is the best candidate. In addition to be applied in automatic control systems, the DAC module can be used to serve as a function generator to generate sine wave, triangular wave and even arbitrary waveform (we provide a library to generate low frequency sin and triangular wave with just a few parameters).
The module employs a 12-bit DAC MCP4725. It requires no external reference voltage (DAC reference is driven from VCC directly), supports 3.3V~5V wide input voltage and has a I2C address selection switch (two address 0x60 and 0x61 are available, which support maximum two modules in cascade). The EEPROM can retain the DAC input while power-off and resume the DAC output upon power-on.
Selection Guide
DFRobot Gravity DAC Module Selection Guide
Figure
SKU
DFR0552
DFR0971
DFR0972
DFR1071
DFR1036
DFR1037
DFR1073
DFR1035
DFR1230
DFR1034
DFR1229
Add to Cart
Description
I2C 12-Bit DAC
2-Ch 0-10V DAC
4-20mA Current DAC
1-Ch 15-Bit (0-10V)
1-Ch PWM (0-10V)
2-Ch PWM (0-2.5V)
2-Ch 15-Bit (0-10V)
1-Ch 15-Bit (0-2.5V)
Hi-Res ±10V / 4-20mA
2-Ch 12-Bit (0-2.5V)
Hi-Res 0-10V / 4-20mA
Comm.
I2C
I2C
I2C
I2C
PWM
PWM
I2C
I2C
I2C/PWM
I2C
I2C/PWM
Res.
12-bit
12-bit
12-bit
15-bit
8-bit
8-bit
15-bit
15-bit
16-bit
12-bit
16-bit
Channels
1
2
1
1
1
2
2
1
1
2
1
Output Range
0~VCC
0-10V / 0-5V
4-20mA (0-25mA)
0-10V / 0-5V
0-10V / 0-5V
0-2.5V / 0-VCC
0-10V / 0-5V
0-2.5V / 0-VCC
±10V, 0-10V, 4-20mA
0-2.5V / 0-VCC
0-10V, 0-10V, 4-20mA
Chip
MCP4725
GP8403
GP8302
GP8211S
GP8101S
GP8501
GP8413
GP8512
GP8630N
GP8503
GP8600
Key Features
Classic model, with EEPROM, cost-effective
Dual-channel industrial voltage, cascade up to 16 devices
Industrial current loop, requires 18-24V power
High precision (0.01%), single channel
PWM driven, easy to use, industrial voltage
PWM driven, dual channel, low voltage control
High precision, dual channel, industrial voltage
High precision, single channel, low voltage control
Flagship, supports bipolar (negative voltage) output
Medium precision, dual channel, low voltage control
16-bit ultra-high precision, multi-function all-in-one
  • 12-bit high accuracy DAC
  • On-board EEPROM, retain DAC input while power-off
  • Gravity I2C interface, plug and play. XH2.54 4P reserved for expansion
  • Wide voltage input, compatible with 3.3V and 5V controllers
  • Small size and easy to install
  • Sensor Calibration
  • Automatic Control Systems
  • Function Generator
  • Input Voltage (VCC): 3.3V~5.0V
  • Output Voltage: 0 ~ VCC
  • Resolution: 12-bit
  • Working Current: <0.2 mA
  • Interface: Gravity I2C (logic level: 0-3.3V)
  • Dimension: 27.0mm*22.0mm
  • Weight: 13.8g
  • Gravity: I2C 12-Bit DAC Module x1
  • XH2.54-4P Header x1
  • FAQ
    MAREO.JACOBS Nov 16, 2021
    Used succesfully to convert temperature to I2C.
