High Temperature Resistant Silicone Wire (10AWG 6mm2 1m Red & Black)
$6.90
SKU: FIT0581
High temperature resistant silicone wire with 10AWG, made of tin-plated copper. It withstands AC600V/DC3KV, 140A, and temperatures -60°C to +200°C. Ideal for robots and models.
High Temperature Resistant Silicone Wire (10AWG 6mm²) is a heavy‑duty power transmission cable designed for high‑current electronic and robotics applications. The conductor uses fine tin‑plated copper strands that resist oxidation while maintaining excellent conductivity. A multi‑strand twisted structure reduces signal interference and improves electrical stability during demanding operation. Rated for AC600V or DC3KV with a maximum current capacity of 140A, this flexible silicone‑insulated cable supports reliable power delivery in high‑performance systems such as robots, ESC circuits, motors, and articulated robot arms.
Note: Power supply voltage must remain within the rated range to avoid reducing cable lifespan. Operation should remain within the specified temperature range of -60 ° C to +200 ° C.
High Current Capacity with Stable Conductivity
This high‑current silicone cable integrates multiple strands of 0.08mm diameter tinned copper wire to ensure efficient power transfer and reduced electrical resistance. The twisted conductor structure improves conductive stability while minimizing interference in electrically noisy environments. A maximum allowable current of 140A enables dependable energy delivery for high‑power components including ESC systems, drive motors, and robotic actuators that demand consistent and low‑loss electrical connections.
Durable Silicone Insulation for Extreme Temperatures
A thin yet robust silica‑gel insulation layer provides strong electrical isolation without sacrificing flexibility. The silicone material offers excellent elasticity, toughness, and resistance to acids and alkalis while maintaining structural integrity across a wide operating temperature range from -60 ° C to +200 ° C. Such thermal resilience makes the flexible power wire suitable for demanding environments where conventional PVC cables may crack, harden, or degrade.
Flexible Structure for Robotics and Model Systems
The finely stranded copper core combined with soft silicone insulation creates a highly flexible wiring solution that withstands repeated bending and movement. This durable electrical cable supports applications requiring constant motion, including robotic joints, UAV power distribution, RC vehicles, and dynamic mechanical assemblies. Reliable conductivity and mechanical resilience make this heavy‑gauge wire a practical choice for advanced hobby electronics and engineering prototypes.
Such high‑temperature silicone wiring is widely used in robotics platforms, aeromodelling, RC cars, ship models, and high‑power electronic assemblies requiring flexible yet durable electrical connections. Strong current capacity and thermal tolerance support reliable performance in experimental builds, industrial prototypes, and engineering education environments.
  • High temperature and low temperature resistance for extreme environments
  • Fine tinned copper strands resist oxidation and improve conductivity
  • Twisted conductor structure reduces signal interference
  • Supports high voltage and high current transmission
  • Flexible silicone insulation with strong elasticity and toughness
  • Robotics power wiring
  • Electronic speed controller (ESC) connections
  • High‑power motor wiring
  • Robot arm power distribution
  • Aeromodelling and RC aircraft
  • RC cars and ship models
  • High‑current electronics prototypes
  • Rated voltage: AC600V/DC3KV
  • Allowable current: 140A
  • Temperature range: -60 ° C ~ +200 ° C
  • Model: 10AWG 6 mm2
  • Inner core material: 0.08mm (diameter) tinned copper wire
  • Insulation material: silica gel
  • High Temperature Resistant Silicone Wire (10AWG 6mm2 Red 1m) x1
  • High Temperature Resistant Silicone Wire (10AWG 6mm2 Black 1m) x1
  • High Temperature Resistant Silicone Wire (10AWG 6mm2 1m Red & Black)
