Solar Power Manager Series
Note 1: OUT1/USB1/USB2 shared 5A current driving capacity (peak current 8A), that is, the total output power of the three outputs should not exceed 5V*5A=25W (peak 40W).
Note 2: To ensure whether the communication devices you use are compatible with the protocols listed, please consult your communication device manufacturer or retailers for details. If your device does not support the USB charging protocol mentioned above, usually it will limit the charging power to 5V*1A=5W for security sake. This is not caused by the failure of the USB output or insufficient output capability.
Nov 20, 2025
Been using it for more than a year now and it proved to be very reliable, easy to work with (except the IO should have been regrouped together and/or accessible through a plug under the board) 9 out of 10
May 10, 2025
This is an amazing product
May 10, 2025
