A solar power management module for IoT projects, charging 12V lead-acid batteries with 18V panels. Features MPPT and multiple outputs for efficient energy use.
Purchase this product and earn 285 reward points, which are tied to VIP membership program.
Learn More >
The DFRobot Solar Power Manager series are designed for IoT projects and renewable energy projects, providing safe and high-efficiency embedded solar power management modules for makers and application engineers. This medium-power high-efficiency solar power management module allows you to charge a 12V lead-acid battery with a maximum of 4A using a standard 18V solar panel.
Solar Power Manager For 12V Lead-Acid Battery is a medium-power high-efficiency solar power management module, which is able to charge a 12V lead-acid battery with a maximum of 4A using a standard 18V solar panel. It is suitable for applications within 100W, such as 12V lighting equipment, security monitoring, small robots, pumps or environmental monitoring stations. It features as MPPT(Maximum Power Point Tracking) function, maximizing the output power of solar panels under various sunlight. Compared with common PWM solar controllers, it can improve charging performance by 10%-30%. Benefited from its small size and light weight, it is easier to embed it in your projects. The module provides dual high-power outputs 5V 5A (OUT1) and 12V 8A (OUT2) and dual USB outputs 5V 2.5A (USB1/USB2). Except USB1, all outputs can be turned ON/OFF by I/O pins of most controllers (3.3V/5V compatible). This feature helps to dynamically power loads and reduce power consumption. Various protection functions are also employed to ensure the safety and stability of the solar systems.
Solar Power Manager For 12V Lead-Acid Battery Board Overview
Over Charge/Over Discharge/Over Current/Reverse Connection Protections
Over Charge/Over Discharge/Reverse Connection Protections
Output Protections
Short Circuit/Over Current Protections
Short Circuit/Over Current/Over Heat Protections
USB Charge IN
Yes
Yes
No
Yes
USB OUT
5V 1A
5V 1.5A
5V 2.5A x2
No
Regulated OUT
One Regulated Output 5V 1A
Three Regulated Outputs 3.3V 1A;5V 1.5A;9V/12V 0.5A
Two Outputs 5V 5A; 12V 8A
One Regulated Output 3.3V 90mA
Dimension
33.0mm×63.0mm
78.0mm×68.0mm
68.0mm×68.0mm
30.0mm×30.0mm
A small and easy-to-use 5V solar power management module.
Applications: Solar Power Bank, Solar Environment Monitors
For 5V Solar Panels within 10W
A complete multifunction solar power management module.
Applications: Small Solar Street Lamp, Solar Powered Robots
For 9V/12V/18V Solar Panels within20w
A medium power solar management module for 12V lead-acid batteries.
Applications: Street lighting, intelligent agriculture, environmental monitoring station, UPS
For 18V Solar Panels within 100W
A micro power solar power management module for low-power sensors and controllers.
Applications: Wireless Sensor Network, BLE iBecon
For 1V/2V/3V Solar Panels within 0.5W
Add to Cart
Constant voltage (18V fixed) MPPT algorithm, maximizing solar energy conversion
Designed for standard 18V solar panels and 12V lead-acid battery
Multiple high efficiency outputs for 12V or 5V large power devices
Full protection functions, a safe and high efficiency solar power module
A variety of status indicators, system status at a glance
Street lighting
Intelligent Agriculture
Environmental Monitoring Station
Solar Power Management IC: CN3767
Solar Input Voltage (SOLAR IN): 15V~25V
Battery Input (BAT IN): 12V Lead-Acid Battery
Charge Current: 4A Max Trickle Charging, Constant Current, Constant Voltage, Float Charging Four Stages Charging dedicated for 12V Lead-Acid Battery
Float Charge Voltage: 13.55V
Over-discharge Protection Voltage: 10.8V
Solar Charge Average Efficiency (18V SOLAR IN): 94%
BAT IN: Over-discharge/Over-charge/Reverse Connection Protections
OUT1-2/USB1-2: Short Circuit/Over Current/Over Heat Protections
Operation Temperature: -40℃~85℃
Dimension: 68.0mm*68.0mm
Note 1: OUT1/USB1/USB2 shared 5A current driving capacity (peak current 8A), that is, the total output power of the three outputs should not exceed 5V*5A=25W (peak 40W).
Note 2: To ensure whether the communication devices you use are compatible with the protocols listed, please consult your communication device manufacturer or retailers for details. If your device does
not support the USB charging protocol mentioned above, usually it will limit the charging power to 5V*1A=5W for security sake. This is not caused by the failure of the USB output or insufficient output capability.
Been using it for more than a year now and it proved to be very reliable, easy to work with (except the IO should have been regrouped together and/or accessible through a plug under the board)
9 out of 10
