HRXL-MaxSonar-WRLT MB7386 Ultrasonic Distance Sensor
$132.00
SKU: SEN0271
Weather-resistant ultrasonic sensor with millimeter resolution, 6Hz read rate, and 10m range. Features include noise rejection, IP67 rating, and multiple outputs.
Purchase this product and earn 1320 reward points, which are tied to VIP membership program. Learn More >
The weather resistant MB7386 HRXL-MaxSonar-WRLT has millimeter resolution and a 6Hz read rate, and provides short to long distance detection and range information from 500mm to 9999mm for the nearest detectable target. It includes various output options: pulse-width, analog voltage, and TTL serial.
The MB7386 from the HRXL-MaxSonar-WR line of outdoor sensors is a rugged ultrasonic sensor component module. This sensor comes in a compact and robust PVC housing which meets the IP67 water intrusion standard and matches standard electrical 3/4-inch PVC pipe fittings.
The HRXL-MaxSonar-WR sensors are factory calibrated to match narrow sensor beam patterns and provide reliable long-range detection zones.
In addition, the MB7386 offers virtually noise free distance readings through the use of high-output acoustic power combined with continuously variable gain, real-time background automatic calibration, real-time waveform signature analysis, and noise rejection algorithms. This holds true even in the presence of many of the various acoustic or electrical noise sources.
  • Resolution of 1-mm
  • 6Hz read rate
  • Internal temperature compensation
  • 42kHz ultrasonic sensor measures distance to objects
  • RoHS Compliant
  • Read from all 3 sensor outputs: Analog Voltage, Serial, Pulse Width
  • Virtually no sensor dead zone, objects closer than 50cm typically range as 50cm
  • Operates from 2.7-5.5V
  • Low 2.9mA average current requirement
  • Small, light weight module
  • Designed for easy integration into your project or product
  • Operational temperature -40°C to +65°C (-40°F to +149°F)
  • Real-time automatic calibration (voltage, humidity, and ambient noise)
  • Firmware filtering for excellent noise tolerance and clutter rejection
  • Weather resistant (IP67), optional chemical resistant F-Option
  • Matches standard electrical 3/4-inch PVC pipe fittings for easy mounting (3/4-inch National Pipe Thread Straight)
  • Long, narrow detection zone
  • TTL Serial Output
  • Our longest range, high-resolution outdoor, weather resistant, ultrasonic sensor
  • Maximum range of 10 meters (394 inches)
  • HRXL-MaxSonar-WRLT (MB7386)     x1
Out Of Stock
