XL-MaxSonar-WRLA1 MB7076 Waterproof Ultrasonic Distance Sensor (20~1068cm, IP67)
$126.50
SKU: SEN0282
Weather-resistant ultrasonic sensor offers 1 cm resolution, 10Hz rate, 20-1064 cm range, and outputs via analog and RS232. Compact, IP67 PVC housing.
Purchase this product and earn 1265 reward points, which are tied to VIP membership program. Learn More >
The weather resistant MB7076 XL-MaxSonar-WRLA1 sensor features centimeter resolution and a 10Hz read rate, provides short to long distance detection and range information from 20cm to 1064cm for the nearest detectable target, and includes various output options: analog envelope, analog voltage, and RS232 serial.
The MB7076 from the XL-MaxSonar-WR line of outdoor sensors is a rugged ultrasonic sensor component module. This sensor comes in a compact and robust PVC housing which meets the IP67 water intrusion standard and matches standard electrical 3/4-inch PVC pipe fittings.
The XL-MaxSonar-WR sensors are factory calibrated to match narrow sensor beam patterns and provide reliable long-range detection zones.
In addition, the MB7076 offers virtually noise free distance readings through the use of high-output acoustic power combined with continuously variable gain, real-time background automatic calibration, real-time waveform signature analysis, and noise rejection algorithms. This holds true even in the presence of many of the various acoustic or electrical noise sources.
XL-MaxSonar-WRLA1(MB7076) Beam Pattern
  • Resolution of 1 cm
  • 10Hz read rate
  • 42kHz Ultrasonic sensor measures distance to objects
  • RoHS Compliant
  • Read from all 3 select sensor outputs: Analog Voltage, Serial, Analog Envelope
  • Operates from 3.0-5.5V
  • Low 3.4mA average current requirement
  • Small, light weight module
  • Designed for easy integration into your project or product
  • Operational Temperature from -40˚C to +70˚C (-40˚F to +160˚F)
  • Real-time automatic calibration (voltage, humidity, ambient noise)
  • Firmware filtering for better noise tolerance and clutter rejection
  • 200,000+ Hours Mean Time Between Failure
  • Weather Resistant (IP67), optional Chemical Resistant F-Option
  • Matches standard electrical 3/4-inch PVC pipe fittings for easy mounting (3/4″ National Pipe Thread Straight)
  • Our longest range outdoor, weather resistant, ultrasonic sensor
  • Analog envelope output for easy troubleshooting and signal processing
  • Maximum range of 1068 cm (450 inches)
  • Long range, narrow detection zone
  • XL-MaxSonar-WRLA1 (MB7076) x1
Only 4 Left
