TS01 Non-Contact Analog Infrared Temperature Sensor (-70℃~270℃, IP65, 0-3V)
$89.00
SKU: SEN0256
  • $86.00 3+ items
  • $85.00 5+ items
  • $82.00 10+ items
Non-contact IR temperature sensor with analog output measures -70℃ to 380℃ with ±0.5°C accuracy. Features IP65 protection and 5° FOV for precise readings.
Purchase this product and earn 890 reward points, which are tied to VIP membership program. Learn More >
DFRobot TS01 IR temperature sensor is a non-contact thermal sensor, which can be used to measure the infrared intensity of the object so as to calculate its surface temperature without touching. The built-in temperature compensation for the sensor greatly ensures the accuracy of the temperature measurement. The all metal package of the sensor makes it able to protect against impact, water, dust and so on. Given stable output data, this temperature sensor can exhibit a much better measurement performance than most other similar products on the market. The product has been calibrated in wide temperature range before leaving the factory. With an operating temperature of -40℃-85℃, the sensor can be used to measure the temperature of -70℃~380℃ while providing a maximum accuracy of 0.5°C.
An optical filter (long-wave pass) that cuts off the visible and near infrared radiant flux is integrated in the package to provide ambient and sunlight immunity. Its FOV is small as 5°, which means for a heat source of 10cm outer diameter, the maximum measuring distance of the sensor can reach up to 116cm.
  • Non-contact Temperature Measurement
  • Operating Temperature Range of Industrial Grade
  • Analog Voltage Output
  • Metal Packaging
  • Supply Voltage: 5.0~24V DC
  • Operating Current: 20mA
  • Signal Output: analog voltage 0~3V
  • Operating Temperature: -40℃~85℃
  • Measuring Temperature: -70℃~270℃
  • Accuracy: ±0.5℃~±4℃
  • FOV: 5°
  • Defense Grade: IP65
  • Probe Diameter: 15.4 mm/0.61”
  • Probe Length: 78 mm/3.07”
  • Cable Length: 1.5m/59.06”
  • Interface Type: DuPont 3Pin+DuPont 1Pin
  • TS01 Non-Contact Analog Infrared Temperature Sensor (-70℃~380℃, IP65, 0-3V) x1
AI-driven Forest Fire Prevention Robot w/ SMS & EZ-Robot
Projects AI-driven Forest Fire Prevention Robot w/ SMS & EZ-Robot
Kutluhan Aktar
Nov 08, 2022
IoT Wireless Infrared Kitchen (Cooking) Thermometer
Projects IoT Wireless Infrared Kitchen (Cooking) Thermometer
Kutluhan Aktar
Nov 10, 2021
Only 11 Left
