Gravity: URM09 Ultrasonic Distance Sensor (2~500cm, I2C)
$12.90
SKU: SEN0304
  • $12.50 3+ items
  • $12.00 5+ items
  • $11.50 10+ items
Ultrasonic sensor for fast ranging and obstacle avoidance with up to 50Hz frequency, temperature compensation, and adjustable measurement ranges of 150cm, 300cm, 500cm.
DFRobot URM09 is an ultrasonic sensor specifically designed for fast ranging and obstacle avoidance application. Its measuring frequency can reach up to 50Hz. The sensor adopts built-in temperature compensation and I2C communication. There are three measurement ranges designed for programs to select: 150cm, 300cm and 500cm. Please note that shorter range will provide shorter ranging cycle and lower sensitivity. You may need to set it according to your actual use. Besides, the sensor is equipped with on-board LDO, which is able to avoid performance attenuation within power supply range.
URM09 Beam Angle
URM09 Beam Angle
If you need want to learn more about ultrasonic sensors, please click here to check DFRobot Ultrasonic Sensor Selection Guide.
  • Supply Voltage: 3.3~5.5V DC
  • Operating Current: 20mA
  • Operating Temperature Range:  -10℃~+70℃
  • Measurement Range: 2cm~500cm (can be set)
  • Resolution: 1cm
  • Accuracy: 1%
  • Frequency: 50Hz Max
  • Dimension: 47mm × 22 mm/1.85”× 0.87”
  • URM09 Ultrasonic Sensor(Gravity I²C)(V1.0)               x1
  • PH2.0-4P Connector     x1
DFRobot URM Ultrasonic Distance Sensor Selection Guide
Blog DFRobot URM Ultrasonic Distance Sensor Selection Guide
Apr 08, 2020
Ultrasonic Sensor Review: Comparing DFRobot URM09, HC-SR04, Devantech SRF02 & Maxbotix MB1040
Blog Ultrasonic Sensor Review: Comparing DFRobot URM09, HC-SR04, Devantech SRF02 & Maxbotix MB1040
Nov 23, 2023
DFRobot URM Ultrasonic Sensors:  High-Performance and Diverse Selection
Blog DFRobot URM Ultrasonic Sensors: High-Performance and Diverse Selection
Aug 15, 2023
Simple radar with Python
Projects Simple radar with Python
Lupin
Feb 22, 2024
Ultrasonic Air Drums
Projects Ultrasonic Air Drums
Bill.Kolicoski
Feb 24, 2023
Only 18 Left
