When you want to measure the AC current, are you still having trouble cutting the wires, wiring or soldering.
Gravity: Analog AC Current
Sensor comes to the rescue, eliminating the need to cut wires or reconnect circuits. Simply clamp the AC transformer probe on the AC line, and then plug the 3.5mm headphone jack into the signal conversion module to read the current AC current value. The analog output is designed to be compatible with 3V3/5V micro-controller. It can be conveniently used for AC current measurement to monitor
AC motors, lighting equipment, air compressors, etc.
Connection Diagram
Gravity: Analog AC Current Sensor connection diagram(Arduino UNO)
Measure and display household appliances AC current
    AC Current Signal Conversion Module
            Input Voltage (VCC): 3.3V-5.5V
            Interface: Gravity Analog (PH2.0-3P,analog voltage output 0.2-2.8V DC)
            AC Voltage Input Range: 0-1V (AC RMS)
            Relative Error: ±4%
            Dimension: 32 × 27 mm /1.26 × 1.06 in
            Weight: 5g
    Open Type AC Transformer Probe
            AC Current Range: 0-10 A
            Signal Output (standard Φ3.5mm 3P plug): 0-1V AC voltage, linear corresponding range 0-10A
            Accuracy: ±1%
            Non-linearity: ≤±0.2%
            Frequency Range: 50Hz ~ 1kHz
            Cable Length: 1m
            Working Temperature: -25 ℃ ~ +70 ℃
            Opening Size: 13 × 13 mm / 0.51 × 0.51 in
            Weight: 50 g
