Connection Diagram
Mar 17, 2026
Fast shipping and easy to work with
Nov 08, 2025
Fantastic sensor for precise environmental monitoring! The Gravity: Analog SHT30 provides highly accurate temperature and humidity readings with excellent stability. I used it with an ESP32 and the results were consistent across multiple tests. The analog output makes integration straightforward — just plug and read without needing complex libraries. It responds quickly to changes in temperature and humidity, making it ideal for smart agriculture, weather stations, or IoT automation. The module is well built, compact, and reliable. Another excellent product from DFRobot that works exactly as described. Highly recommended!
