A02YYUW Waterproof Ultrasonic Sensor for Arduino / ESP32 / Home Assistant (IP67, 3~450cm, UART)
$15.90
SKU: SEN0311
Waterproof ultrasonic sensor with IP67 rating, measures 3-450cm, 3cm blind spot. Compatible with Arduino, ESP32, Raspberry Pi, ideal for smart home projects.
Purchase this product and earn 159 reward points, which are tied to VIP membership program. Learn More >
Looking for a waterproof distance sensor that doesn't sacrifice close-range accuracy? The A02YYUW is an enclosed, IP67-rated ultrasonic ranging module built for harsh environments. While standard exposed sensors fail quickly in humid conditions, and split-design sensors suffer from large dead zones, the A02YYUW delivers stable distance readings from 3cm to 450cm with a precise 1mm resolution. With 3.3V-5V logic tolerance and a standard 9600 bps UART interface, it wires directly to your microcontrollers—making it an excellent choice for liquid level monitoring and outdoor proximity detection.. The ranging module seamlessly integrates with Arduino, ESP32, Raspberry Pi, and enjoys support for ESPHome, making Home Assistant automations easier than ever.
Native ESPHome & Home Assistant Integration (UART Version)
Skip the complex C++ coding. The A02YYUW ultrasonic sensor has native platform support in ESPHome, making it dead-simple to pull water level metrics directly into your Home Assistant dashboard.
Maker Pro-Tip for Home Assistant: Because the ultrasonic sensor outputs data multiple times per second via its UART bus, raw data can fluctuate slightly. We highly recommend applying Sensor Filters (such as sliding_window_moving_average) in your ESPHome YAML configuration to smooth out the readings.
(Note: The official ESPHome component specifically supports this UART version of the A02YYUW. PWM and RS485 versions are not supported by the default integration.)
Pair this ultrasonic sensor with a low-power IoT board like the FireBeetle 2 ESP32-C6, and your DIY sump pump monitor or rain barrel tracker will be up and running in minutes.
A02YYUW Waterproof Ultrasonic Sensor compatible with ESPHome & HomeAssistant
True IP67 Waterproofing for Long-Term Stability
Humidity can ruin a project. Unlike sensors with exposed circuit boards (like the HC-SR04) or inconvenient split designs (JSN-SR04T), the A02YYUW ultrasonic distance sensor features a fully sealed, integrated body. Its IP67 waterproof rating means it can withstand dust, splashes, and even temporary submersion. This robust design ensures stable, reliable data output over the long term, making it the ideal choice for outdoor applications or continuous liquid level monitoring.
IP67 Waterproof A02YYUW Ultrasonic Sensor
Measure What Matters: The 3cm Ultra-Small Blind Spot Advantage
When monitoring a tank, every centimeter counts. The JSN-SR04T, has a massive 20cm blind spot, making it impossible to detect when a tank is nearly full.
The A02YYUW sonar sensor solves this with an industry-leading 3cm blind spot. This allows for accurate distance readings right up to the top, providing precise control over water levels and preventing overflows in automated systems.
A02YYUW Waterproof Ultrasonic Sensor features 3cm Blind Spot
Beam Directionalities Diagram
Maker-Friendly & Versatile for All Projects
This ultrasonic distance detection sensor is designed with the DIY community in mind. It operates on a flexible 3.3V-5V power supply and communicates via a standard UART serial port, making it incredibly easy to connect to any microcontroller. It's fully compatible with popular platforms like Arduino, ESP32, and Raspberry Pi. A connection cable is included, allowing projects to be up and running in minutes, not hours.
A02YYUW Waterproof Ultrasonic Sensor compatible with Arduino / ESP32 / Raspberry Pi
  • Smart Plant Watering System: Monitor the reservoir level and automatically trigger a water pump.
  • Water Tank Level Monitor: Get real-time water volume data from a home water tank or rain barrel.
  • Aquarium / Fish Tank Automation: Create an auto top-off system to prevent low water levels.
  • Smart Trash Can: Detect if the trash can is full and needs to be emptied.
  • Working Voltage: 3.3V - 5V
  • Average Current: ≤ 8mA
  • Blind Spot Distance: 3 cm
  • Detection Range: 3 cm - 450 cm
  • Output Interface: UART Serial Port
  • Response Time: 100 ms
  • Operating Temperature: -15°C to 60°C
  • Waterproof Level: IP67
  • Measurement Accuracy: ±1 cm
  • Reference Angle: 60°
  • A02YYUW Waterproof Ultrasonic Sensor x1
  • PH2.0-4P Connector x1
     How to Select the Ultrasonic Sensor
    Blog How to Select the Ultrasonic Sensor
    May 04, 2023
    Automated Driveway Gates Version 2
    Projects Automated Driveway Gates Version 2
    KGray
    Nov 01, 2022
    Robert.Warren Apr 04, 2026
    This sensor works just fine on ESP32 and on UNO boards
    Gareth.Carr Feb 13, 2026
    Angle is just a bit too much but works perfect.
    TAKAO.SAKAMOTO May 31, 2025
    Easy install to Raspberry Pi with pyhton.
