The ESP32-PICO-KIT-1 is a compact development board featuring the ESP32-PICO-V3 System-in-Package (SiP) module. The module integrates the ESP32 dual-core processor, a 40 MHz crystal, and 4 MB of SPI flash. The board provides complete Wi-Fi (802.11 b/g/n) and Bluetooth v4.2 BR/EDR/BLE functionality. All I/O pins are broken out to 18-pin headers on each side for easy interfacing with breadboards. It includes an onboard USB-to-UART bridge, allowing for direct programming and debugging from a PC via a USB port.
The ESP32-PICO-KIT-1 development board also integrates a USB-to-UART bridge circuit, allowing developers to burn and debug firmware directly through the USB port of a PC.
In order to facilitate hardware connection, all IO signals and system power pins on ESP32-PICO-V3 are led to pads on both sides of the development board (18 x 0.1"). The above 18 pads are also led to pin headers and can be used Dupont wire connections.
Wi-Fi
Bluetooth
Hardware
Apr 20, 2026
excellent build quality and stable hardware. recommended
Apr 20, 2026
very stable and well made, we use these for prototyping
Apr 20, 2026
very stable and solid well made board
