ESP32-PICO-KIT Development Board (Wi-Fi & Bluetooth)
$13.90
SKU: DFR0625
The ESP32-PICO-KIT-1 is a development board featuring Wi-Fi and Bluetooth capabilities, a USB-to-UART bridge circuit, and various module interfaces for easy hardware connectivity.
The ESP32-PICO-KIT-1 is a compact development board featuring the ESP32-PICO-V3 System-in-Package (SiP) module. The module integrates the ESP32 dual-core processor, a 40 MHz crystal, and 4 MB of SPI flash. The board provides complete Wi-Fi (802.11 b/g/n) and Bluetooth v4.2 BR/EDR/BLE functionality. All I/O pins are broken out to 18-pin headers on each side for easy interfacing with breadboards. It includes an onboard USB-to-UART bridge, allowing for direct programming and debugging from a PC via a USB port.
The ESP32-PICO-KIT-1 development board also integrates a USB-to-UART bridge circuit, allowing developers to burn and debug firmware directly through the USB port of a PC.
In order to facilitate hardware connection, all IO signals and system power pins on ESP32-PICO-V3 are led to pads on both sides of the development board (18 x 0.1"). The above 18 pads are also led to pin headers and can be used Dupont wire connections.
Wi-Fi
  • Protocols: 802.11 b/g/n (802.11n up to 150 Mbps)
                A-MPDU and A-MSDU aggregation and 0.4 µs guard interval support
  • Frequency: 2.4 ~ 2.5 GHz
    Bluetooth
  • Protocols: Bluetooth V4.2 BR/EDR and BLE specification
  • Radio: NZIF receiver with –97 dBm sensitivity
                Class-1, class-2 and class-3 transmitter
                AFH
  • Audio: CVSD and SBC
    Hardware
  • Module Interfaces: ADC, DAC, touch sensor, SD/SDIO/MMC Host Controller, SPI, SDIO/SPI Slave Controller, EMAC, motor PWM, LED PWM, UART, I2C, I2S, infrared remote controller, GPIO, pulse counter
  • On-chip sensor: Hall sensor
  • Integrated crystal: 40 MHz crystal
  • Integrated SPI flash: 4 MB
  • Operating voltage/Power supply: 2.7V~3.6V
  • Average Operating current: 80 mA
  • Minimum current delivered by power supply: 500 mA
  • Operating temperature range: –40 °C ~ 85 °C
  • Package size: 47 x 20.3 x 10 mm/1.85 x 0.80 x 0.39”
    • ESP32-PICO-KIT-1 Development Board x1
    ESP32 cpplinq Tutorials Menu
    Blog ESP32 cpplinq Tutorials Menu
    Apr 25, 2021
    Blog ESP32 HTTP server Tutorials Menu
    Apr 25, 2021
    ESP32 Soft AP Tutorials Menu
    Blog ESP32 Soft AP Tutorials Menu
    Apr 25, 2021
    ESP32 MicroPython Tutorials Menu
    Blog ESP32 MicroPython Tutorials Menu
    Apr 01, 2021
    ESP32 Arduino Tutorials Menu
    Blog ESP32 Arduino Tutorials Menu
    Apr 20, 2021
    ESP32 PS3 and PS4 Tutorials Menu
    Blog ESP32 PS3 and PS4 Tutorials Menu
    Apr 25, 2021
    Premjit.Tarafdar Apr 20, 2026
    excellent build quality and stable hardware. recommended
    very stable and well made, we use these for prototyping
    very stable and solid well made board
