Fermion: Monochrome 0.96" 128x64 I2C/SPI OLED Display (Breakout)
$14.50
SKU: DFR0650
  • $14.00 3+ items
  • $13.70 5+ items
  • $13.30 10+ items
A 0.96” OLED display with SSD1306 chip, 128x64 white pixels, supports SPI/I2C, 3.3V/5V. Ideal for wearables, mini consoles, and desktop widgets.
Purchase this product and earn 145 reward points, which are tied to VIP membership program. Learn More >
This 0.96” OLED display module uses the SSD1306 drive chip, has 128x64 self-illuminating white pixels, and adopts two communication methods: SPI/ I2C, I2C in default. With its high contrast, simple wiring and low power consumption, it can be applied to many display applications, such as wearable display devices, Mini small game consoles, desktop widgets, etc.
This 0.96” OLED display module supports both 3.3V and 5V. The display module adopts a high-contrast, low-power OLED display. It is compatible with controllers such as Arduino UNO, Leonardo, ESP32/ESP8266, FireBettle-M0 and so on. Internal power-on reset processing, I2C communication methods, so that your welding line will be more convenient and simpler. If you want to change I2C communication to SPI, you just need to change the resistor position. In addition, the display is in an aluminum frame package that protects the screen from damage, and also prevents you from scratching that caused by the glass edge of the screen.
Note: Turn the pixels off when you are not using the display to prevent the use of some pixels too long to darken them, which will cause the brightness uniformity problem.
Selection Guide
Monochrome I2C OLED Display Selection Guide
Figure
SKU
DFR0647
DFR0648
DFR0650
Chip
SSD1306
SSD1306
SSD1306
Voltage Input
3.3/5V
3.3/5V
3.3/5V
Resolution
128x32
128x32
128x64
Interface
I2C
I2C
I2C/SPI
Welding Method
Chip-mounting pad on the back
Ordinary welding hole
Size
41x12 mm
33x20 mm
30x30 mm
1. Small size, ultra-narrow design 2. Display 2 rows of 16 pixel characters 3. Chip-mounting pad
1. Small size 2. Display 2 rows of 16 pixel characters
1. Display 4 rows of 16 pixel characters 2. Support I2C/SPI 3. Iron frame to protect the screen
Recommended
Suitable for users with certain hands-on ability to build up applications requiring space and appearance
Suitable for entry-level makers
Applicable for users who want to display much content with high-speed SPI refresh
Add to Cart
  • Self-illuminating OLED display
  • Controllable pixels and low power consumption
  • I2C/SPI communication, I2C in default
  • Supports power-on reset
  • Thermometer
  • Desktop weather display
  • Kitchen weighing machine
  • Air quality detector
  • Mini Game consoles
  • Wearable display
  • Operating voltage: 3.3V to 5V
  • Color: white pixels
  • Number of pixels: 128 columns x 64 rows
  • Interface: I2C (in default) / SPI
  • I2C address: 0x3C
  • Drive chip: SSD1306
  • Brightness: 180 (Typ) cd/m2
  • Full-screen lighting power: approx. 24mA*3.3V/5V(I2C);
                                                        approx. 27mA*3.3V/5V(SPI)
  • Full-screen off power consumption: approx. 2mA*3.3V/5V(I2C);
        approx. 2.87mA*3.3V/5V(SPI)
  • Operating temperature: -30°C to 70°C
  • Display area: 21.744 x 10.864(mm) / 0.86”x 0.42”
  • Size: 30.00x30.00 mm / 1.18”x 1.18”
  • Weight: 4.2 g
  • Monochrome 0.96" 128x64 I2C/SPI OLED Display x1
  • 2.54 chip-mounting pin-6P x1
Blog Monochrome I2C OLED Display Selection Guide
Apr 26, 2020
DIY A Simple Three-axis Accelerometer Data Logger
Projects DIY A Simple Three-axis Accelerometer Data Logger
Frances
Mar 02, 2023
The Millennium Falcon Audio Visualizer
Projects The Millennium Falcon Audio Visualizer
alankrantas
Feb 20, 2021
KOUBELAN RICHARD.AKPAGNI Jul 13, 2023
This is a good product. I like
Only 5 Left
