Night Camera Module for Raspberry Pi
$79.00
SKU: SEN0338
  • $77.60 3+ items
  • $76.00 5+ items
  • $73.60 10+ items
A camera module compatible with Raspberry Pi boards, featuring Sony IMX327 sensor for clear imaging in day/night, supports 1080p video, noise reduction, and adjustable settings.
Purchase this product and earn 790 reward points, which are tied to VIP membership program. Learn More >
Night Camera Module for Raspberry Pi is a high‑sensitivity imaging solution designed for low‑light monitoring, machine vision development, and embedded vision projects. Built around the Sony IMX327 STARVIS sensor, this compact CSI camera delivers clear 1080p video even in dim environments without requiring infrared illumination. Compatibility with Raspberry Pi boards enables seamless integration into edge‑AI systems, robotics platforms, and industrial monitoring setups. The STARVIS-based vision module combines excellent light sensitivity, reliable color reproduction, and flexible image tuning, making the compact camera board suitable for day‑night observation, smart surveillance prototypes, and advanced computer‑vision experimentation.
Figure: Front and back view of the night vision camera module
STARVIS Low‑Light Imaging Performance
Equipped with the Sony 1/2.8‑inch IMX327LQR‑C STARVIS sensor, the low‑light camera board provides excellent sensitivity and strong signal‑to‑noise performance in dim environments. The 2.07‑megapixel sensor captures 1920×1080 video at up to 30 frames per second while maintaining stable color reproduction and sharp image detail. Combined with a 4mm focal length lens and large 2.9µm pixel size, the embedded vision sensor excels in nighttime wildlife observation, low‑illumination surveillance, and industrial inspection where standard camera modules often struggle.
Advanced ISP and Image Enhancement
An integrated ISP enables multiple real‑time image optimization functions including 2D/3D noise reduction, defog processing, backlight compensation (BLC), and DOL‑WDR. Adjustable parameters such as brightness, contrast, sharpness, and saturation allow precise tuning for different environments. The vision processing camera outputs uncompressed UYVY YUV422 8‑bit video data, ensuring consistent image quality for computer vision pipelines, machine learning inference, and automated visual analysis systems.
Flexible CSI Integration for Embedded Vision
The compact imaging module connects through a universal CSI interface and communicates through IIC control, enabling straightforward deployment in embedded computing projects. Support for MIPI CSI‑2 two‑lane video transmission provides stable high‑bandwidth data transfer up to 1.188Gbps. Adjustable day/night switching with external trigger compatibility and IR‑CUT motor control expands usability for adaptive lighting environments, making the CSI camera board suitable for robotics vision, intelligent monitoring systems, and edge computing platforms.
Figure: Camera module connected to a Raspberry Pi development board
High sensitivity, flexible image control, and CSI compatibility make this embedded night‑vision camera well suited for machine vision systems, intelligent analysis platforms, industrial automation equipment, face recognition prototypes, and ADAS research projects. The compact imaging solution also works effectively for wildlife monitoring and nighttime observation where reliable low‑light performance is essential.
  • Sony IMX327 STARVIS 1/2.8" CMOS sensor for excellent low‑light sensitivity
  • Supports 1920×1080 Full HD video at up to 30fps
  • MIPI CSI‑2 two‑lane interface for high‑speed embedded vision transmission
  • Uncompressed UYVY YUV422 8‑bit output for stable image processing
  • Integrated ISP with 2D/3D noise reduction, DOL‑WDR, and defog enhancement
  • Adjustable brightness, contrast, sharpness, saturation, mirror, and flip settings
  • Supports IR‑CUT control and external day/night switching trigger
  • Compatible with standard M12 or M16 lens mounts
  • Compact design suitable for robotics, surveillance, and machine vision systems
  • Low‑light machine vision systems
  • Nighttime wildlife observation and monitoring
  • Embedded AI and computer vision development
  • Industrial inspection and automation
  • Face recognition and smart security prototypes
  • ADAS research and intelligent transportation systems
  • Sensor: Sony IMX327LQR-C STARVIS
  • Pixels: 2.07m pixels
  • Resolution: 1920x1080
  • Image Size: Diagonal 6.46mm (Type 1/2.8)
  • Unit Cell Size: 2.9um(H)*2.9um(V)
  • SNR1s Value: 0.23lx/0.18lx
  • Frame Rate: 1080 p@25/1080 p@30 fps
  • Exposure: Auto or Manual
  • White Balance: Auto or Manual
  • Shutter: 1/25(1/30)s to 1/50,000s
  • Support Slow Shutter
  • Denoising: 2D/3D noise reduction
  • Image Setting: Brightness, Contrast, Sharpness, Saturation, Flip, Mirror
  • Image Enhancement: BLC, DOL-WDR, Defog
  • Day/Night Switch: Manual or IR-CUT filter with external trigger
  • Lens: Support M12*0.5 or M16*0.5 depend on lens mount
  • Lens Mount: MTV12 or MTV16
  • Mounting Hole: 2 screw holes with diameter of 2.2mm Centre distance of 20mm
  • PCB Connector: BTB050040-F1D
  • Communication Interface: IIC, 3.3VDC
  • Video Data Interface: MIPI: 2Lane, CSI2 YUV 422-8bit Data Type, Bandwidth: 1.188Gbps
  • IR-CUT Control: IR-CUT motor control, 3.3VDC
  • Day/Night External Trigger: compatible with 3.3VDC to 12 VDC
  • Operating Conditions: -10℃-50℃, Humidity 95% or less, non-condensing
  • Power Supply: 3.3VDC
  • Power Consumption: 3.3VDC, 1.2W
  • Dimension: 38*38*8mm/1.50*1.50*0.31”(not include lens and IR-CUT)
  • Night Camera Module for Raspberry Pi ×1
Only 6 Left
