micro:Maqueen Plus V2 (Ni MH Rechargeable Battery) with HUSKYLENS and micro:bit V2
$127.20
SKU: MBT0021-EN-2
An advanced educational robot kit designed for STEAM learning, featuring easy assembly, multiple expansion ports, and compatibility with AI cameras.
Purchase this product and earn 1272 reward points, which are tied to VIP membership program. Learn More >
Note:  This product includes micro: Maqueen Plus v2, Gravity: HUSKYLENS, and micro: bit V2 board.
Batteries are not included.
What’s new in Maqueen Plus V2?
1. Two versions to choose from: 4 AA battery and 18650 battery
2. New plastic box with a deeper base, enough room for the assembled car
3. Frosted acrylic protective plate at the bottom, more durable and reliable
4. The number of Line-tracking sensors has changed from 6 to 5, more convenient to program and optimize line-tracking codes
5. Employs the motors whose parameters are the same as previous Maqueen, running steadily and smoothly
6. Changes ultrasonic sensor to SR04, easier to install
7. Add 4 RGB ambient lights at the base, RGB car lights have been changed to LEDs
8. Delete the less usable magnetic encoder
Maqueen Plus V2 is the latest version of the STEAM educational robot Maqueen Plus. Optimized with more expansion ports, larger capacity power supply, and larger body, it is fully compatible with more peripheral components like HuskyLens AI camera, Maqueen Mechanic Kits, which makes it an accessible STEAM robot teaching tool for primary and secondary students. Maqueen Plus V2 is not only suitable for classroom teaching, but also can be used for after-school extended exercises and robot competitions.
Besides all the functions of Maqueen Lite, it offers richer and more flexible functions and stronger performance. Whether you have ever used Maqueen Series products or not, you’ll find it very easy to get started.
micro:Maqueen Plus V2 - an Advanced STEM Education Robot for micro:bit
  • No complex assembly, get started in minutes
  • More IO expansion ports: 3.3V IOx7, 5V IOx3, I2Cx3
  • 5 line-tracking sensors, reliable and flexible
  • Larger body, more flexible expansion methods
  • Two versions to choose from: AA battery and 18650 battery
        AA battery version supports 1.2V Ni MH battery or 1.5V alkaline battery, while 18650 battery version supports 3.7V 18650 battery
  • Works well with HuskyLens AI camera
  • Rich peripherals: IR receiver, LED car lights, RGB ambient lights, buzzer, ultrasonic sensor, etc.
  • Frosted acrylic protective plate at the bottom
  • Storage box with a deeper base to provide enough room for the assembled Maqueen Plus car
  • STEM Education
  • Power Supply:MBT0021-EN: 1.5V AA alkaline battery x 4 or 1.2V AA Ni-MH battery x 4
  • Support micro:bit V1 and V2
  • N20 All-metal Gear Motor x 2
  • Buzzer x 1
  • 5V IO (P0 P1 P2) x 3
  • 3.3V IO (P0 P1 P2 P8 P12 P13 P14 P15)
  • 3.3V I2C x 2
  • 5V I2C x 1
  • Large Size LED Car Lights x 2
  • RGB Ambient Lights x 4
  • Line-tracking Sensor x 5
  • Line-tracking Sensor with One-key Calibration
  • IR Receiver x 1
  • SRO4 Ultrasonic Module x 1
  • Dimension: 136mm×65mm/5.35×2.56"
  • Programming Platform: Mind+, MakeCode
  • Wiki Address:
  • MakeCode Library Address: https://github.com/DFRobot/pxt-DFRobot_MaqueenPlus_v20
  • Maqueen Plus V2 (AA battery) Vehicle body x 1
  • (Note: the motor, vehicle wheel, support wheel, and battery panel have been installed before delivery)
  • H-SR04 Ultrasonic Sensor x 1
  • Line-tracking Map x 1
  • Gravity: HUSKYLENS - An Easy-to-use AI Machine Vision Sensor x 1
  • micro: bit board V2 x 1
  • Type-C & Micro 2-in-1 USB Cable x1
  • FAQ
