Argon ONE V2 Raspberry Pi 4 Aluminium Case
$24.90
SKU: DFR0711
The product is an aluminum case compatible with Raspberry Pi 4, featuring a cooling system, standard HDMI ports, a power button, and GPIO pin extensions. It includes a fan, adapter board, and magnetic cover.
Argon One V2 Aluminum Case for Raspberry Pi 4 delivers a refined enclosure solution combining thermal management, interface optimization, and premium industrial design. The upgraded computing enclosure integrates a built‑in adapter board that converts the micro‑HDMI interface of Raspberry Pi 4 into a standard HDMI port, eliminating the need for additional adapter cables when connecting displays. A solid aluminum alloy body with a Space Grey finish provides both structural protection and passive heat dissipation. This compact SBC housing also reorganizes ports to the rear side for a cleaner workspace while maintaining convenient access to essential connections and system controls.
Argon ONE Raspberry Pi 4 Aluminium Case
Figure: Argon ONE Raspberry Pi 4 Aluminium Case
Note: This product does not include Raspberry Pi 4 series motherboards. In order to ensure system safety, installation of the enclosure is recommended before inserting the TF card.
Integrated Cooling Architecture
This aluminum computing enclosure incorporates a hybrid cooling design combining passive conduction and active airflow. A thermal pad transfers processor heat directly to the metal housing, turning the entire body into a large heat sink. An internal PCB-mounted cooling fan further improves airflow to reduce thermal buildup during sustained workloads. Ventilation openings on both the top and bottom surfaces enhance circulation efficiency, allowing this SBC thermal management solution to maintain stable operating temperatures during long-running computing or multimedia tasks.
Rear Port Layout with Smart Power Control
A redesigned rear interface arrangement keeps cables organized and visually clean while maintaining easy hardware access. Integrated circuitry enables advanced power management through a multifunction power button. Supported operations include safe startup, controlled shutdown, reboot commands, and forced shutdown when necessary. This intelligent power interface improves usability in embedded computing setups, media center builds, and compact desktop environments where convenient system control and tidy cable routing remain important.
GPIO Expansion and Interface Optimization
An integrated expansion PCB extends GPIO access while preserving enclosure protection. Color‑coded pins and printed labels simplify hardware identification, making the single-board computer case convenient for electronics prototyping and development projects. The expansion board also relocates HDMI and audio connections to the side panel, maximizing internal space efficiency and forming a balanced square aluminum structure. This interface organization improves usability for makers, developers, and embedded system integrators working with Raspberry Pi hardware.
Precision Aluminum Structure
A CNC‑machined aluminum chassis forms a rigid square enclosure precisely aligned with the Raspberry Pi 4B board layout. Carefully positioned mounting holes ensure accurate board fitment, while ventilation slots complement the internal fan to enhance cooling efficiency. The magnetic top cover allows convenient sliding removal for maintenance or hardware access. This durable SBC enclosure combines aesthetic design with reliable thermal performance for professional development workstations and compact computing deployments.
Applications include home media centers, compact desktop systems, embedded development platforms, maker projects, and educational computing environments requiring effective cooling and durable enclosure protection for Raspberry Pi 4 hardware.
  • Aluminum alloy enclosure with Space Grey finish for durability and improved heat dissipation
  • Integrated cooling system combining thermal pad conduction and active cooling fan
  • Standard HDMI output via built-in adapter board, eliminating micro‑HDMI adapters
  • Rear-mounted ports for clean cable management
  • Multifunction power button supporting safe shutdown, restart, and forced shutdown
  • Color‑coded and labeled GPIO extension board for convenient hardware access
  • Magnetic removable top cover for easy maintenance
  • Raspberry Pi media center builds
  • Compact desktop computing systems
  • Embedded Linux development platforms
  • Maker and DIY electronics projects
  • Educational computing environments
  • Edge computing or lightweight server nodes
  • Unique square structure.
  • Upper cover with magnetic suction buckle for easy sliding removal.
  • Built-in cooling fan, heat conduction column, and ventilation hole, the heat dissipation effect is better.
  • Precise hole design for Raspberry Pi 4B board.
  • Dimension: 106*95*30mm
  • Aluminum Alloy Upper Case (With Cooling Fan) x1
  • Aluminum Alloy Lower Case x1
  • Magnetic Suction Top Cover x1
  • Screw x8
  • Heat Dissipation Sticker x2
  • HDMI and audio interface adapter board x1
  • Non-Slip Rubber Pad x1
  • Review
    Chris. Jun 20, 2021
    The Argon One is a really good case for the Raspberry Pi 4, the case itself does a good job as a heat sink and the fan will kick in during prolonged intense CPU usage. It is very well made and the GPIO cover works really well, the magnets that keep it attached are very strong, they need force to release the lid. The power button does work but the 3 second hold to turn off is too close to the 5 second hold for instant power off, the delay should be 1 second instead of 3.
    Jan.Holtzhausen Feb 23, 2026
    Bulletproof and stylish, STILL the benchmark for all Pi cases
    Ohsoo. Feb 22, 2022
    NICE PRODUCTS !
