Fermion: 2.8” 320x240 TFT LCD Resistive Touchscreen with MicroSD Card Slot (Breakout)
$24.90
SKU: DFR0665
  • $24.20 3+ items
  • $23.50 5+ items
  • $23.00 10+ items
2.8" LCD touchscreen module with 320x240 pixels, SPI communication, resistive touch, GDI interface, and MicroSD slot. Compatible with multiple controllers.
With 320x240 color pixels, this 2.8” LCD display module adopts the ILI9341 driver chip and integrates XPT2046 that supports resistive touch. The display module adopts SPI(4-line) communication mode, performing excellently in the angle of view(60/60/60/60). It also supports the GDI interface (the GDI interface should be used in conjunction with the main control board with GDI interface). Just plug it in, and you’re good to go. The module, featuring high resolution, wide view angle, and simple wiring, can be applied in many display applications: sensor monitoring and warning, controller display, flash or 3D displays, Touch interface, etc.
The 2.8” LCD display module can be operated at 3.3V~5V, and is compatible with multiple main-controllers: UNO, Leonardo, ESP32, ESP8266, FireBeetle M0, etc. Use the GDI interface to work with M0, which could effectively reduce wiring steps. Besides, there is an onboard MicroSD card slot for displaying more pictures.
Note: The product doesn’t contain a MicroSD Card. You can click here to buy one.
  • Wide-angle of view
  • Resistive Touchscreen
  • High Resolution
  • GDI Interface, plug, and play
  • Onboard MicroSD Card Slot
  • Sensor Monitoring and Warning
  • Controller Display
  • Flash or 3D Display
  • Touch Interface
  • Operating Voltage: 3.3V-5.5V
  • Display Color: 16-bit Color Depth (RGB565)
  • Driver Chip: ILI9341
  • Touch Chip: XPT2046
  • Pixel: 320x240
  • Communication Mode: SPI
  • Brightness (cd/m2): 300(TYP)
  • Full-screen Consumption: 43.5mA*5V/3.3V
  • Operating Temperature: -10℃~+60℃
  • Display Area: 57.60x43.20mm/2.27x1.70”
  • Module Dimension: 80.00x50.00mm/3.15x1.97”
  • Mounting Hole Diameter: 2mm
  • 2.8”320x240 TFT LCD Touchscreen with MicroSD x1
  • 2.54-12P Black Single Row Pin Header x1
  • FPC0.5-18PIN 10cm Reverse Connection Line x1
    No-Code Gas Detector Prototype
    Projects No-Code Gas Detector Prototype
    RosarIoT
    Aug 09, 2024
    DIY Arduino (FireBeetle) E-Scooter
    Projects DIY Arduino (FireBeetle) E-Scooter
    KGray
    Jul 26, 2023
