9g 300° Clutch Servo
$5.00
SKU: SER0053
  • $4.90 3+ items
  • $4.80 5+ items
  • $4.60 10+ items
The servo features clutch function and protection, preventing damage from external forces. It offers 300° rotation, large torque, and can be controlled via Arduino.
When a servo is operated under complex circumstances such as robot and model, it may get stuck, be burned or damaged due to external forces, which could bother you a lot...
Now DFRobot is launching a series of servos with clutch function and electronic protection that can solve your problems perfectly.
Clutch Function
When the angle of a servo is changed by external forces during normal operation, the servo can automatically reset and continue working through clutch function, which prevents it from being damaged.
Electronic Protection
After being blocked for 5 seconds, the servo will automatically turn off its power to avoid getting burned.
Servo Internal Structure
This servo features large torque, stable performance, accurate running angle and easy to install. The operating voltage is 4.8~6V. When the servo is powered at 6V, its stall torque will exceed 1.2Kg. There are no limited switches inside the servo so it can rotate smoothly in 360 degrees (manually only). Meanwhile, the servo could operate fluently with minimal power, and you can just supply power to it by normal battery or USB. In addition, users can directly control the servo using servo libraries in Arduino IDE and let it reach a maximum 300 degrees rotation angle within the pulse range of 500-2500μsec.
Mechanical Dimensions
  • Operating Voltage: 4.8-6V DC
  • Static Current: ≤8mA at 6.0V
  • No-load Current: ≤50mA at 4.8V
           ≤60mA at6.0V
  • Stall Current: ≤550mA at 4.8V
             ≤650mA at 6.0V
  • Rated Torque: ≥0.32kgf·cm at 4.8V
              ≥0.4kgf·cm at 6.0V
  • Stall Torque: ≥1.0kgf·cm at4.8V
            ≥1.2kgf·cm at6.0V
  • Operating Angle: 300°±10°
  • Communication Mode: PWM
  • Pulse Width Range: 500~2500μs
  • 9g 300° Clutch Servo x1
  • Servo Plate & Accessories x1 set
    Selection Guide for Clutch Servo
    Blog Selection Guide for Clutch Servo
    Nov 30, 2020
    Halloween trick or treat automata with Voice Recognition module
    Projects Halloween trick or treat automata with Voice Recognition module
    RoniBandini
    Oct 16, 2023
    Out Of Stock
