DFRobot 9g 180° Clutch Servo – Damage-Proof Micro Servo for Arduino & STEM Robotics
$5.00
SKU: SER0049
  • $4.90 3+ items
  • $4.80 5+ items
  • $4.60 10+ items
The servo features clutch function and electronic protection to prevent damage. It offers large torque, stable performance, and easy installation.
What is the DFRobot 9g Clutch Servo?
The DFRobot 9g 180° Clutch Servo is an advanced micro servo motor designed to solve the two most common problems in DIY electronics: stripped gears and burnt-out motors. By combining a built-in mechanical clutch with smart electronic stall protection, this 9g servo is virtually damage-proof, making it the ultimate durable upgrade for standard SG90 servos in Arduino projects, RC models, and STEM education.
How Does It Prevent Damage?
1. Mechanical Clutch Function (Prevents Stripped Gears)
  • The Problem: Traditional micro servos break when forced manually or subjected to sudden physical shocks.
  • The Solution: This servo removes internal mechanical limits. If the servo arm experiences strong external force (e.g., a robot taking a fall or someone twisting the arm), the clutch slips to safely release the stress. Once the force stops, the servo automatically returns to its programmed angle.
  • 2. Electronic Stall Protection (Prevents Motor Burnout)
  • The Problem: When a servo gets jammed, it draws continuous high current, leading to overheating, melted casings, or even fire hazards.
  • The Solution: Built-in smart circuitry monitors the motor. If the servo is blocked for 5 continuous seconds, it automatically cuts power to the motor. Simply remove the blockage or cycle the power, and the servo resumes normal operation.
  • Best Applications for the 9g Clutch Micro Servo
  • STEM Education & School Labs: An essential, "student-proof" educational robotics component. It drastically reduces replacement costs caused by coding errors or rough handling during lab sessions.
  • Bionic Robots & Hexapods: Delivers an impressive stall torque of up to 2.0kgf·cm @ 6.0V in a standard 9g footprint. The clutch acts as a shock absorber for robot joints during walking or falls.
  • Interactive Art Installations: Safely yields to external force if the public touches or grabs moving mechanical parts, protecting both the audience and your project.
  • Arduino DIY Projects: 100% plug-and-play compatible with standard Arduino libraries. Ideal for desktop robotic arms, ultrasonic sensor pan-tilt mounts, and automated smart door locks.
  • Technical Setup & Pro-Tips for Makers
    To get the most out of your DFRobot 9g Clutch Servo, follow these technical guidelines:
  • How to Unlock the Full 180° Range: The default pulse width for the standard Arduino servo library is often limited (544~2400μs). To achieve the full 180°±10° sweep, explicitly define the pulse range in your code: myservo.attach(pin, 500, 2500);
  • Power Supply Requirements: While highly power-efficient, if your robotics project uses more than 4 of these servos simultaneously, we strongly recommend using a dedicated 5V/6V BEC (Battery Eliminator Circuit) to maintain the maximum 2.0kgf·cm torque and prevent microcontroller resets.
  • 360° Manual Rotation vs. Electronic Control: Because there are no internal hard stops, you can smoothly rotate the servo 360 degrees by hand only when unpowered. Under PWM electronic control, the operational angle remains precisely 180 degrees.
  • Internal Structure of DFRobot 9g 180° Clutch Servo
    Mechanical Dimensions of DFRobot 9g 180° Clutch Servo
  • Operating Voltage: 4.8-6V DC
  • Static Current: ≤8mA at 6.0V
  • No-load Current: ≤110mA at 4.8V ≤120mA at6.0V
  • Stall Current: ≤700mA at 4.8V ≤800mA at 6.0V
  • Rated Torque: ≥0.45kgf·cm at 4.8V ≥0.55kgf·cm at 6.0V
  • Stall Torque: ≥1.6kgf·cm at4.8V ≥2.0kgf·cm at6.0V
  • Operating Angle: 180°±10°
  • Communication Mode: PWM
  • Pulse Width Range: 500~2500μs
  • Gear Number: 40
  • Gear Diameter: 3mm
  • 9g 180° Clutch Servo x1
  • Servo Plate & Accessories x1 set
    Intelligent Follow-up Fan Based on YOLO Facial Keypoint Detection and Hand Gesture Detection
    Projects Intelligent Follow-up Fan Based on YOLO Facial Keypoint Detection and Hand Gesture Detection
    auroraAA
    Nov 19, 2025
    Selection Guide for Clutch Servo
    Blog Selection Guide for Clutch Servo
    Nov 30, 2020
