Fermion: AS7341 11-Channel Visible Light Sensor (Breakout)
$16.50
SKU: SEN0365
  • $16.00 3+ items
  • $15.70 5+ items
  • $15.20 10+ items
The 11-Channel Visible Light Sensor detects colors accurately using eight visible light channels, a near-IR channel, and ambient light flicker detection.
Purchase this product and earn 165 reward points, which are tied to VIP membership program. Learn More >
We live in a colorful world, but how much do you really know about color? You eyes may deceive you, while the sensors don’t lie. This AS7341 11-Channel Visible Light Sensor-Breakout can tell you the truth about color.
DFRobot AS7341 11-Channel Visible Light Breakout Board employs the new generation of AS7341 spectral sensor IC launched by the well-known AMS company. The sensor features eight channels for the visible light, one channel for near-IR, and one channel without a filter. Also it integrates a dedicated channel to detect ambient light flicker. Besides that, this sensor comes with 6 independent 16-bit ADC channels for data processing in parallel. The two on-board extra-bright LEDs can supply light in dark environment.
Visible Spectrum Sensor-breakout
RGB Color Sensor vs AS7341 Sensor
  Yellow LED
WS2812 Simulated Yellow
Recognition result of RGB color sensor
Red+Green
Red+Green
Recognition result of  AS7341 visible light sensor
Yellow
Red+Green
You can click to find information about visible light.
Related Project:
Spectrophotometer Experiment Based on AS7341 Spectral Sensor
  • 8 optical channels covering the visible spectral range
  • 50Hz and 60Hz ambient light flicker detection
  • 6 independent 16-bit ADC channels
  • High accuracy color detection and matching
  • Color mixing effect detection
  • Lighting color temperature adjustment
  • Lighting atmosphere control
  • Modern plant cultivation
  • Power Supply: 3.3V~5V
  • Visible Light Detection Range: F1(405-425nm), F2(435-455nm), F3(470-490nm), F4(505-525nm), F5(545-565nm), F6(580-600nm), F7(620-640nm), F8(670-690nm)
  • Operating Current(LED Off): <5mA
  • LED Driving Current: Class 1-20 (4-42mA)
  • I2C Address: 0x39
  • Operating Temperature Range: -30℃~85℃
  • Operating Humidity Range: 5%RH~85%RH
  • Dimension: 18*14mm/0.71*0.55”
  • AS7341 Visible Light Sensor x1
  • 2.54-7P Single Row Black Pin Header x1
  • Review
    Ohsoo. Aug 23, 2021
