BMP388 Digital Pressure Sensor Module delivers high‑resolution barometric pressure and temperature measurement in a compact breakout board designed for embedded development and environmental sensing projects. Built around Bosch’s advanced piezo‑resistive sensing technology, this barometric sensing module provides exceptional accuracy, low noise output, and very low power consumption. Native library support enables quick integration with Arduino platforms, simplifying atmospheric data acquisition for robotics, drones, and IoT devices. Compared with earlier Bosch sensors such as BMP180 and BMP280, this environmental pressure sensor board offers improved sampling rates, higher precision, and a smaller hardware footprint for modern embedded systems.
High‑Precision Altitude and Pressure Measurement
Bosch BMP388 sensing technology enables extremely accurate atmospheric pressure monitoring with relative pressure accuracy of ±0.08 hPa. Such precision corresponds to roughly ±0.66 m altitude variation, enabling reliable elevation tracking for aerial robotics, indoor positioning experiments, and environmental monitoring systems. This digital barometric sensing board also measures temperature simultaneously, providing reliable environmental context data. Stable readings and low noise characteristics support applications where precise altitude change detection or pressure trend monitoring is essential.
Optimized for Low Power and Compact Embedded Designs
This breakout pressure sensing module operates with extremely low current consumption around 0.5 mA, supporting battery‑powered IoT devices, portable environmental monitors, and remote sensing nodes. A compact 22 mm × 30 mm board footprint allows easy integration into drones, robotics controllers, and compact electronic enclosures. Bosch’s robust MEMS architecture provides strong EMC resistance while maintaining stable performance across a wide operating temperature range, making this environmental sensing board suitable for long‑term deployment in embedded systems.
Flexible Communication for Diverse Controller Platforms
The atmospheric sensing module supports both I2C and SPI communication, enabling compatibility with a wide variety of microcontroller development platforms and embedded computing boards. The default I2C address simplifies quick system integration, while SPI support provides an alternative for higher communication speed or multi‑device setups. Support for 3.3V–5.5V operating voltage further broadens controller compatibility, allowing seamless connection with numerous robotics controllers, data loggers, and experimental sensing systems.
Accurate pressure sensing, altitude tracking capability, and low‑power operation make this barometric sensor breakout suitable for drone flight control, indoor floor‑level detection, portable weather stations, and environmental data logging. Reliable atmospheric data also supports robotics navigation, altitude‑aware IoT deployments, and experimental atmospheric research projects requiring stable pressure and temperature measurements.
