Fermion: URM13 High Sensitivity Ultrasonic Distance Sensor Breakout (15~900cm, I2C / UART / PULSE)
$24.00
SKU: SEN0352
  • $23.30 3+ items
  • $22.80 5+ items
  • $22.00 10+ items
Ultrasonic sensor with TRIG Pulse, UART, I2C support. Compact design, sensitive, noise detection, real-time calibration. Compatible with Arduino, Raspberry Pi.
Purchase this product and earn 240 reward points, which are tied to VIP membership program. Learn More >
DFRobot URM13 is an ultrasonic ranging sensor with open single-probe. It supports TRIG Pulse-triggered ranging (SR04 compatible), UART, and I2C communication protocols, which brings more possibilities for actual using scenarios. With a small and compact body, the sensor works well with 3.3V or 5V mainboards like Arduino and Raspberry Pi, easy to use and integrate into various applications. Besides, the UART mode employs standard Modbus-RTU protocol and integrates receive/send control output to allow users to easily expand the RS485 interface using an external RS485 transceiver.
The URM13 is positioned to be a professional and advanced ultrasonic sensor. The integration of a new precision circuit design and smart detection algorithms on the sensor makes it much smaller and lighter, while still maintaining excellent sensitivity. At the same time, the URM13 sensor is able to automatically detect ambient and electrical noise, and complete the dynamic adjustment and calibration of sensor parameters in real-time, which ensures its stable performance in various complex application scenarios.
URM13 Ultrasonic Sensor Board Overview
Board Overview
URM13 High Sensitivity Ultrasonic Distance Sensor Beam Angle
  • Small and compact body
  • Excellent sensitivity
  • Automatic noise detection and real-time calibration
  • HC-SR04 compatible
  • UART and I2C interface, support to expand RS485
  • Power Supply: 3.3~5.5V DC
  • Max Instantaneous Work Current: 350mA
  • Operating Temperature: -10℃~+70℃
  • Effective Measuring Range: 15cm~900cm
  • Resolution: 1cm
  • Accuracy: 1%
  • Measuring Frequency: 10Hz Max
  • Dimension: 22×20mm/0.87×0.79”
  • URM13 Ultrasonic Sensor x1
  • 2.54 Black Single-Row 4PIN Connector x1
    DFRobot URM Ultrasonic Distance Sensor Selection Guide
    Blog DFRobot URM Ultrasonic Distance Sensor Selection Guide
    Apr 08, 2020
    DFRobot URM Ultrasonic Sensors:  High-Performance and Diverse Selection
    Blog DFRobot URM Ultrasonic Sensors: High-Performance and Diverse Selection
    Aug 15, 2023
    Out Of Stock
